External hard drive and timeshift
I have a 128GB external usb drive attached to Zorin OS18 CORE machine. I initially dedicated it to TIMESHIFT. All seemed to work well. I recently decided to move a few files to that drive along side timeshift. Wouldn't happen. I believe it had to do with permissions .... and the drive was read only. From what I have researched, I think it's a 'simple' unmount, chmod command, and a mount command but I'm not good at those commands. :grinning_face:
Is this any help to GETTING some help in adding a few files to the timeshift drive? I don't see a 128GB device below:
$ lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 66.8M 1 loop /snap/core24/1243
loop1 7:1 0 91.7M 1 loop /snap/gtk-common-themes/1535
loop2 7:2 0 48.1M 1 loop /snap/snapd/25935
loop3 7:3 0 4K 1 loop /snap/bare/5
loop4 7:4 0 395M 1 loop /snap/mesa-2404/1165
loop5 7:5 0 1.7M 1 loop /snap/gnome-system-monitor/193
loop6 7:6 0 66.8M 1 loop /snap/core24/1267
loop7 7:7 0 50.9M 1 loop /snap/snapd/25577
loop8 7:8 0 669.8M 1 loop /snap/gnome-46-2404/145
sda 8:0 0 931.5G 0 disk
├─sda1 8:1 0 512M 0 part /boot/efi
└─sda2 8:2 0 931G 0 part /
or
owner@Acer-Zorin:~$ df -h
Filesystem Size Used Avail Use% Mounted on
tmpfs 781M 14M 768M 2% /run
/dev/sda2 916G 23G 847G 3% /
tmpfs 3.9G 53M 3.8G 2% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
efivarfs 100K 79K 17K 84% /sys/firmware/efi/efivars
/dev/sda1 511M 6.2M 505M 2% /boot/efi
tmpfs 781M 152K 781M 1% /run/user/1000
/dev/sdb1 117G 20G 91G 19% /media/owner/e32c1324-4179-4993-a179-762af0e63b20
owner@Acer-Zorin:~$
Thank you in advance for any help.
Hi, just to be clear, you did format the external drive to Ext4 FS?
I see you have a lot of snap packages. I suspect these cannot be included in Timeshift because snap and flatpak use 'sandboxing' (but it has been shown on other web pages that the 'sandboxing' is not really sandboxing of apps!). Snap (and Flatpak) run in their own environments which I avoid at all costs (as well as flatpaks).
