I recently bought a 32 inches monitor with HDMI/Display Port and USB-C (that also provide 65W power to the laptop) and connect it to my laptop
I have no problem in using this monitor with the USB-C and Win11.
I cannot use the monitor when using the USB-C and Zorin 16.2...it work when using the HDMI...
Any idea why it does not work when connected with USB-C?
USB-C + WIn11: OK
USB-C + Zorin 16.2: NOK...the external monitor is simply not detected (not listed in Display settings)
HDMI + Zorin 16.2: OK
DP...not tested as I do not have DP port on my laptop
not urgent as it work with HDMI...however if there is an easy trick to make it work with USB-C would be happy...
uname -r gave me this: 5.15.0-60-generic
sudo apt install linux-modules-extra-$(uname -r) gave me this:
[sudo] password for :
Reading package lists... Done
Building dependency tree
linux-modules-extra-5.15.0-60-generic is already the newest version (5.15.0-60.66~20.04.1).
linux-modules-extra-5.15.0-60-generic set to manually installed.
coinor-libcbc3 coinor-libcgl1 coinor-libclp1 coinor-libcoinmp1v5
coinor-libcoinutils3v5 coinor-libosi1v5 gir1.2-animation-glib-0
gir1.2-ges-1.0 libanimation-glib0 libanimation0 libges-1.0-0 libjs-jquery
libjs-jquery-ui pitivi python-matplotlib-data python3-cycler
python3-kiwisolver python3-matplotlib python3-numpy python3-pyparsing
zorin-os-feedback
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
...not sure to understand your question...
the USB-C port on my laptop is a USB-C port...that's all what I can say...I doubt it would be part of the video card...by the way I think I have a GPU: GeForce GTX 1660 Ti while the monitor has something named AMD Freesynch...is that relevant for this case....?
