I'm looking to move to zorin as my daily driver from windows and am pretty noob to linux desktop.
Anyway, I have a problem with zorin recognising my 2 external monitors (BenQ GW2765 & ViewSonic VP2365wb) connected to my Dell XPS 15 9500 laptop via Plugable DisplayLink UD-6950H HDMI/USB3 Hub.
Graphics card is NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] / Mesa Intel UHD Graphics (CML GT2)
Here's the output of dpkg -l | grep -i nvidia:
ii libnvidia-cfg1-535:amd64 535.183.01-0ubuntu0.22.04.1 amd64 NVIDIA binary OpenGL/GLX configuration library
ii libnvidia-common-535 535.183.01-0ubuntu0.22.04.1 all Shared files used by the NVIDIA libraries
ii libnvidia-compute-535:amd64 535.183.01-0ubuntu0.22.04.1 amd64 NVIDIA libcompute package
ii libnvidia-compute-535:i386 535.183.01-0ubuntu0.22.04.1 i386 NVIDIA libcompute package
ii libnvidia-decode-535:amd64 535.183.01-0ubuntu0.22.04.1 amd64 NVIDIA Video Decoding runtime libraries
ii libnvidia-decode-535:i386 535.183.01-0ubuntu0.22.04.1 i386 NVIDIA Video Decoding runtime libraries
ii libnvidia-encode-535:amd64 535.183.01-0ubuntu0.22.04.1 amd64 NVENC Video Encoding runtime library
ii libnvidia-encode-535:i386 535.183.01-0ubuntu0.22.04.1 i386 NVENC Video Encoding runtime library
ii libnvidia-extra-535:amd64 535.183.01-0ubuntu0.22.04.1 amd64 Extra libraries for the NVIDIA driver
ii libnvidia-fbc1-535:amd64 535.183.01-0ubuntu0.22.04.1 amd64 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-fbc1-535:i386 535.183.01-0ubuntu0.22.04.1 i386 NVIDIA OpenGL-based Framebuffer Capture runtime library
ii libnvidia-gl-535:amd64 535.183.01-0ubuntu0.22.04.1 amd64 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii libnvidia-gl-535:i386 535.183.01-0ubuntu0.22.04.1 i386 NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii linux-modules-nvidia-535-6.5.0-41-generic 6.5.0-41.41~22.04.2+1 amd64 Linux kernel nvidia modules for version 6.5.0-41
ii linux-modules-nvidia-535-generic-hwe-22.04 6.5.0-41.41~22.04.2+1 amd64 Extra drivers for nvidia-535 for the generic-hwe-22.04 flavour
ii linux-objects-nvidia-535-6.5.0-41-generic 6.5.0-41.41~22.04.2+1 amd64 Linux kernel nvidia modules for version 6.5.0-41 (objects)
ii linux-signatures-nvidia-6.5.0-41-generic 6.5.0-41.41~22.04.2+1 amd64 Linux kernel signatures for nvidia modules for version 6.5.0-41-generic
ii nvidia-compute-utils-535 535.183.01-0ubuntu0.22.04.1 amd64 NVIDIA compute utilities
ii nvidia-driver-535 535.183.01-0ubuntu0.22.04.1 amd64 NVIDIA driver metapackage
ii nvidia-firmware-535-535.183.01 535.183.01-0ubuntu0.22.04.1 amd64 Firmware files used by the kernel module
ii nvidia-kernel-common-535 535.183.01-0ubuntu0.22.04.1 amd64 Shared files used with the kernel module
ii nvidia-kernel-source-535 535.183.01-0ubuntu0.22.04.1 amd64 NVIDIA kernel source package
ii nvidia-prime 0.8.17.1 all Tools to enable NVIDIA's Prime
ii nvidia-settings 510.47.03-0ubuntu1 amd64 Tool for configuring the NVIDIA graphics driver
ii nvidia-utils-535 535.183.01-0ubuntu0.22.04.1 amd64 NVIDIA driver support binaries
ii screen-resolution-extra 0.18.2 all Extension for the nvidia-settings control panel
ii xserver-xorg-video-nvidia-535 535.183.01-0ubuntu0.22.04.1 amd64 NVIDIA binary Xorg driver
Any ideas for how I can get my monitors to be recognised?
Screen-1 must be one of your of the monitor you have attached and Monitor-1 is the laptop screen? And it should see another one as well? Does this setup work in Windows or other OS'? (to rule out faulty sticks and wires)
An update on this - I've got one of the monitors to work now when plugged into a different USB C dock. So it seems that it's an issue with the Plugable dock.
I've got my main monitor working when plugged into displayport instead of hdmi on the plugable, and I can plug my other monitor (which doesn't have displayport) into the other usb hub so I think I'm sorted now.
Not sure why HDMI isn't working on the displayport but at least I've got somewhere with it.
