Hello, I just installed zorin os 18, but I can't use f11 or f12 keys like I did in zorin os 17. F11 was intended to put a window into full screen and F12 open the web browser console.
Does anyone know how should I enable it ?
Thank you
Thank you
Do You have seperate F Keys or are they as a 2nd Layer on the Numbers Keys?
Yes I have separed F keys (and they are working fine on windows)
Okay, what Keyboard do You have and what Keyboard Layout is set up in the Settings?
I have the G915 TKL (from logitech G), and I tried with American English and qwerty-fr (https://qwerty-fr.org/).
Note: Everything worked perfectly on Zorin OS 17
Unplug and plug back the keyboard seems fix it
Oh, that was an surprisingly easy Solution. But good that it works now. Keep an Eye on it and report back.
