Hey, I've tried to Upgrade my Zorin OS Pro Lite installation through the provided tool. It quickly failed, when I ran apt-get update on the commandline I was met with this message.
Err:15 https://packages.mozilla.org/apt mozilla InRelease
The following signatures couldn't be verified because the public key is not available: NO_PUBKEY
I fixed it by running the following commands and verified, that the command does now work correctly
sebastian@sebastian-linux:~/Documents/Coding/nethogs$ gpg --keyserver keyserver.ubuntu.com --recv-keys C0BA5CE6DC6315A3
gpg: key C0BA5CE6DC6315A3: public key "Artifact Registry Repository Signer <artifact-registry-repository-signer@google.com>" imported
gpg: Total number processed: 1
gpg: imported: 1
sebastian@sebastian-linux:~/Documents/Coding/nethogs$ gpg --export --armor C0BA5CE6DC6315A3 | sudo apt-key add - && sudo apt-get update
OK
After that I ran the upgrade utility again, it got further into the upgrade process and then failed again. Now I feel like I am stuck.
sudo apt-get update
Get:1 https://nvidia.github.io/libnvidia-container/stable/ubuntu18.04/amd64 InRelease [1.484 B]
Hit:2 http://ppa.launchpad.net/zorinos/apps/ubuntu jammy InRelease
Hit:3 http://security.ubuntu.com/ubuntu jammy-security InRelease
Hit:4 http://de.archive.ubuntu.com/ubuntu jammy InRelease
Hit:5 http://ppa.launchpad.net/zorinos/drivers/ubuntu jammy InRelease
Hit:6 http://de.archive.ubuntu.com/ubuntu jammy-updates InRelease
Hit:7 http://ppa.launchpad.net/zorinos/patches/ubuntu jammy InRelease
Hit:8 http://de.archive.ubuntu.com/ubuntu jammy-backports InRelease
Hit:9 https://linux.teamviewer.com/deb stable InRelease
Get:10 https://download.opensuse.org/repositories/Emulators:/Wine:/Debian/xUbuntu_20.04 ./ InRelease [1.559 B]
Hit:11 http://ppa.launchpad.net/zorinos/stable/ubuntu jammy InRelease
Hit:12 https://packages.microsoft.com/repos/code stable InRelease
Ign:13 https://repo.vivaldi.com/stable/deb stable InRelease
Hit:14 https://repo.vivaldi.com/stable/deb stable Release
Hit:15 https://packages.mozilla.org/apt mozilla InRelease
Hit:16 https://packages.zorinos.com/stable jammy InRelease
Hit:17 https://packages.zorinos.com/patches jammy InRelease
Hit:19 https://packages.zorinos.com/apps jammy InRelease
Hit:20 https://packages.zorinos.com/drivers jammy InRelease
Hit:21 https://packages.zorinos.com/premium jammy InRelease
Fetched 3.043 B in 2s (1.759 B/s)
File "/usr/lib/cnf-update-db", line 8, in <module>
from CommandNotFound.db.creator import DbCreator
File "/usr/lib/python3/dist-packages/CommandNotFound/db/creator.py", line 12, in <module>
import apt_pkg
ModuleNotFoundError: No module named 'apt_pkg'
Reading package lists... Done
E: Problem executing scripts APT::Update::Post-Invoke-Success 'if /usr/bin/test -w /var/lib/command-not-found/ -a -e /usr/lib/cnf-update-db; then /usr/lib/cnf-update-db > /dev/null; fi'
E: Sub-process returned an error code
sudo apt-get upgrade
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
The following packages have unmet dependencies:
libapt-pkg-perl : Depends: perlapi-5.30.0 but it is not installable
libcairo-gobject-perl : Depends: perlapi-5.30.0 but it is not installable
libcairo-perl : Depends: perlapi-5.30.0 but it is not installable
libfile-fcntllock-perl : Depends: perlapi-5.30.0 but it is not installable
libgjs0g : Depends: libgirepository-1.0-1 (>= 1.71.0) but 1.64.1-1~ubuntu20.04.1 is installed
Depends: libgirepository-1.0-1-with-libffi8 (>= 1.64)
libglib-object-introspection-perl : Depends: perlapi-5.30.0 but it is not installable
python3 : PreDepends: python3-minimal (= 3.8.2-0ubuntu2) but 3.10.6-1~22.04 is installed
Depends: libpython3-stdlib (= 3.8.2-0ubuntu2) but 3.10.6-1~22.04 is installed
python3-yaml : Depends: python3 (>= 3.10~) but 3.8.2-0ubuntu2 is installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
sudo apt --fix-broken install
Correcting dependencies... failed.
E: Error, pkgProblemResolver::Resolve generated breaks, this may be caused by held packages.
E: Unable to correct dependencies
apt-mark showhold returns nothing.
