Fan control Acer Laptop
Hello, everyone!
Could you help me?
I need a fan control solution for laptop Acer Predator Helios Neo 16 i7 (PH16) wich I use Zorin OS (core).
I tried to use the "Fan Control" software by wiiznokes, available in the store, but it didnt work.
A person suggested me this article: Fan speed control - ArchWiki
But, besides the fact that this is about ach linux, the article dont show a solution for acer laptops.... and to be fair, i dont know how to adapt the solution of the article for acer latops. In the first place, would it even be possible to adapt the solution?
I prefer not to use the "intelligent cooling mode" in BIOS/UEFI.
A thank you guys in advance!
i have this installed helps control the fans on the RX 6600XT i have
fans on that dont turn on till its hot enough to fry an egg....now they run at 40% speed all the time and as it gets hotter it speeds up
my fan curve with it
Did You add the udev Rules like mentioned here:
thank you, sir.
I will try this and i will come back here to let the people know if it worked
Thank you! Happy to be here.
I did. I really dont know why it didnt work.
Hmm ... aren't You able to set up a Fan Curve in Your BIOS? I don't mean some automatic Mode or similar. I mean to manaully set up the Percentages and Temperatures.
With Software, I would know something but this is for Graphic Cards; so, I would doubt that it works for You ...
Interesting! I have not thought about that. I will look into it.
Thank you very much.
