Hello everyone,
earlier today I've installed ZorinOS Core on my VivoBook notebook. Previosly I had Debian 11, openSUSE Leap, Fedora and Windows 11 as well.
On all Linux distributions I had the same problem, CPU fans are running constatly on very high speed, above 3000 RPMs. Just after the system boot, the fans are still running at OK speed, around 2000 RPMs, but once I start using the OS the speed goes sometimes even above 4500 and I am not doing lost of stuff, e.g. browsing the web, discord opened, terminal with vim/nvim, spotify...just normal activities.
Just right now I have Brave with 5 tabs, Terminal, File Manager and VSCode, the CPU is around 5-10% load and ~33% of the memory is occupied. I am constantly checking the sensorsin terminal, the average CPU temp is ~50°C and still the fan speed is 3400RPM
asus-isa-0000
Adapter: ISA adapter
cpu_fan: 3400 RPMucsi_source_psy_USBC000:001-isa-0000
in0: 0.00 V (min = +0.00 V, max = +0.00 V)
curr1: 0.00 A (max = +0.00 A)BAT0-acpi-0
Adapter: ACPI interface
in0: 11.98 Vcoretemp-isa-0000
Package id 0: +49.0°C (high = +100.0°C, crit = +100.0°C)
Core 0: +43.0°C (high = +100.0°C, crit = +100.0°C)
Core 1: +46.0°C (high = +100.0°C, crit = +100.0°C)
Core 2: +42.0°C (high = +100.0°C, crit = +100.0°C)
Core 3: +45.0°C (high = +100.0°C, crit = +100.0°C)nvme-pci-e100
Adapter: PCI adapter
Composite: +27.9°C (low = -0.1°C, high = +76.8°C)
(crit = +79.8°C)acpitz-acpi-0
temp1: +50.0°C (crit = +103.0°C)
For me this is a software issue, previosly when I was using W11 I didn't had these issues, once I switched to Linux, every distro is having this problem and I can't figure out what causes it. Any ideas?
I have already tried:
- switching the distro
- install the Nvidia drivers
- changing the kernel
Nothing seems to be working
The specs are:
11th Gen Intel® Core™ i5-11300H
16GB RAM
Nvidia RTX 3050
