Thank you very much for the suggestion.
Regards
There must be a simple way to change your default sound card. I just did a websearch using "make sound card default" and this came up. It looks similar to your case and the source (it's FOSS) is considered a good one:
Hello:
I will see the proposed solution.
Greetings.
