when I was trying openSUSE tumbleweed (Gnome) I noticed that when I open Nautilus I can click on the path to edit it. Here on Zorin, I can't do that, I have to press Ctrl+L in order to edit it. My guess is that openSUSE has the newer and/or unmodified Nautilus manager that has "click to edit path" option.
With Nautilus, you can start typing something right away and it will search for files and folders matching that string. However, if you start with ~ or / it will use that string for navigation, instead of a query.
This is a good example of why managing expectations is important. Windows and Linux are different systems; it is not unreasonable to expect things to behave differently, and to expect certain adjustments in workflow. Even when that means trying and installing other tools that may work better for a particular use case.
Personally, I think anyone willing to type a file location manually should be prepared to, well, do some typing. I speak from experience here, as I use the keyboard for a lot of my work which involves navigating file systems up and down all day long using the terminal.
As a rolling-release distribution, it has the latest possible packages available where as Zorin inherits the Debian release model of updating only when things are tested and stable. This explains the difference in versions between the two.
Makes sense. Is there a way to "force" upgrade Nautilus to the latest version? Sorry for my ignorance but I am totally new to Linux I like Linux so far, especially Zorin, and I am trying to make my new "home" cozy and familiar so it doesn't scare me away I am aware that I have to make some compromises (I already did), but I am also trying not to make compromises where I do not have to. I will do my best to replicate experience, but if something is impossible - I will accept that
Although you can extend the behavior of Nautilus, to a certain point, with some custom scripts as well. For simple things like that it shouldn't be too difficult.
This depends on the program. Sometimes, you can update to a later version, though not the latest. It's a balancing act between installed dependencies that don't break each other.
But Nautilus is designed to integrate tightly with the rest of the desktop; updating a dependency here may break something else over there... it's just way more trouble than it's worth.
It's a good thing that you are asking these questions. There's nothing wrong with wanting and trying to replicate things that you are already familiar with. It's just that a lot people give up at the first sign of trouble and I've noticed that, often, this is the result of frustration because the expectation is to have an identical experience.
And just to be clear @Clintre, I'm not implying that your friends are like this, I'm just trying to make a point – I'm again speaking from personal experience as I've seen this happen many times.
So, don't give up on trying to find that sweet spot and ask away when you have questions. You've already done more than most, which is simply giving things a fair chance.
Correct, and to be clear this will probably happen when the next major version of Zorin OS, version 18, is released. Given the current pace of development this would probably be around 18~20 months from now. Just an estimation on my part, there's no public roadmap on this.
Unfortunately not. My options are (from Portuguese to English):
New folder
New document...
Add bookmark
Past
Select All
Open in terminal
Properties
I in Zorin OS 17 core.
NOTE: I was just playing with OpenSuse on DistroSea and saw that it is similar
to yours. Maybe Debian and Opensuse are using a more advanced version than
Zorin.
What Debian and OpenSUSE have in common in this regard is that neither distribution modifies Gnome. But Zorin OS does... so I guess it's possible this option was removed for some reason, and if so, it could be brought back?
