The fingerprint function on my laptop not function more, it is a "Lenovo ThinkPad T16 Gen 4" with installed OS "Zorin OS 17.3 Core".
The command on terminal "fprintd-verify $USER" has this output:
Impossible to verify: GDBus.Error:net.reactivated.Fprint.Error.NoSuchDevice: No devices available
I report also this information:
Command: lsusb | grep -i synaptics
Output: Bus 003 Device 002: ID 06cb:00f9 Synaptics, Inc.
I do not have a fingerprint reader, so I have no personal experience.
I have done a couple of websearches using: "Bus 003 Device 002: ID 06cb:00f9 Synaptics, Inc. Ubuntu 22.04" as searchterm.
I don't know if there is a workable Synaptics driver that can be used. Maybe others with this Synaptics fingerprint scan and Lenovo hardware combination can offer better advice.
I wonder if a software update (kernel update) occurred that upset your sensor.
Try rolling back to previous kernel to test that theory.
From your startup grub menu, select "Additional Options for Zorin"
Then choose a previous kernel generic version.
Boot with that version and test.
PS.
that linux mint link I previously posted is active when I click it.
Having done some searching there is no driver in any linux kernel up to 6.12 which is why fprintd is required. Apparently it works out of the box on Ubuntu 24.04, so once Zorin 18 comes out you should be good to go.
