Fingerprint reader not working, need help finding drivers for '10a5:a900'
Hey Linux community,
I'm a longtime Linux user and I'm loving every minute of it! However, I've hit a roadblock with my fingerprint sensor '10a5:a900'.
I've been trying to find the right drivers for it for the past 6 months with no luck. When I run lsusb, I see the sensor listed as:
Bus 003 Device 002: ID 10a5:a900 FPC FPC Sensor Controller L:0002 FW:22.26.2.29
I've tried Googling and troubleshooting on my own, but I haven't been able to find a solution. I've even attempted to enroll my fingerprint using fprintd-enroll, but it throws an error saying "No devices available".
I'm using a Honor MagickBook Pro X14 (2023), and I'm really hoping someone in the Linux community can help me out with this specific sensor. Any assistance would be greatly appreciated!
Sadly, there does not appear to be a driver for this device:
Please remember that most hardware is made for that other OS and relies heavily on reverse engineering to work under Linux kernel. If a fingerprint reader is essential I would recommend a Linux compatible solution from here:
https://www.thinkpenguin.com/gnu-linux/optical-usb-fingerprint-reader-gnulinux-edition-tpe-f4500
I finally have a working driver for the FPC fingerprint sensor 10a5:a900!
Back in March 2024, I was stuck with the same unsupported device and posted about it here (unfortunately that thread is locked now):
If you have this sensor in your Honor MagicBook Art 14 or Pro X14, here's the solution:
:link: GitHub - cityji/honor-magickbookpro-fingerprint-driver: Working fingerprint enrollment and login on Linux for the Fingerprint Cards 10a5:a900 match-on-host sensor (HONOR MagicBook). libfprint + MR396 + fixes for the image-format mismatch that made every capture silently fail. · GitHub
One-line install:
curl -fsSL https://raw.githubusercontent.com/cityji/honor-magickbookpro-fingerprint-driver/main/bootstrap.sh | bash
Usage
fprintd-enroll
fprintd-verify
Tested on Pop!_OS 24.04 (COSMIC). Should work on Ubuntu, Fedora, and Arch too.
Also listed on the official libfprint wiki now: Making sure you're not a bot!
Hope this helps anyone who's been stuck as long as I was!
