It appears it is not listed which means the Linux kernel does not have a driver for it:
" Fingerprint readers on the Acer Swift SF314-71 (and similar 3/Go models) often use unsupported proprietary sensors (e.g., EgisTec or Elantec) that lack native Linux drivers, making them frequently non-functional. Support depends on libfprint/fprintd drivers, which currently may not cover this specific hardware.
Actionable Steps for Troubleshooting:
- Identify the Sensor: Run
lsusb in the terminal to find the specific Vendor:Product ID for your sensor.
- Check Compatibility: Search the fprint supported devices list for your ID.
- Install
fprintd: Install the necessary packages for fingerprint support in your distribution (e.g., sudo apt install fprintd for Ubuntu).
- Community Support: Check forums like Acer Community for specialized community-driven fixes.
Currently, there is no official Linux driver from Acer for this model's fingerprint sensor, as these laptops are designed for Windows.
SF314-71-56U3 Swift Go-Fingerprint sensor is not working under Linux
16 Jan 2025 — If you look on the support site, they have separate Windows drivers for the Elantec and Carewe sensors, so there are hardware differences between the two. Worse...
Acer Community
Acer Swift 3 SF 316-51 - Fingerprint is not working in linux deepin ( ...
6 Jan 2023 — We can often look up which chip is used, and that gives a pointer to where there might be drivers. Acer doesn't usually ship any models with Linux, so don't gra...
[image]
Acer Community
[image]
Setup fingerprint login on Arch Linux with LightDM - DEV Community
26 Feb 2025 — * Check Your Fingerprint Reader. Make sure your fingerprint reader is supported. ... * Install the Needed Packages. Open a terminal and install fprintd (it will...
[image]
DEV Community
[image]
How To Add Fingerprint on Ubuntu 20.04.5 LTS on Acer Swift sf314-41 ...
2 Sept 2022 — You need to find the fingerprint sensor device ID with lsusb and then check here if it is supported.
[image]
Reddit
[image]
Fingerprint reader support
The GNOME desktop supports fingerprint management through its Users Settings panel. Most Linux distributions support fingerprint login through fprintd.
[image]
fprintd
[image]
Debian Bullseye 11.2 touchscreen and fingerprint reader drivers
6 Mar 2022 — For the fingerprint reader you need fprintd and libpam-fprintd. Any touchscreen needs an absolut XY-input driver, like wacom. This is a little tricky depending ...
Facebook
Aspire A515-47. Are there drivers for Linux?
10 Jul 2025 — Search for community support: Check forums like the Acer Community or Linux Mint Forums to see if other users have found solutions for the Aspire A515-47 or sim...
Acer Community
AI responses may include mistakes. Learn more"
