In my experience any of the closed threads talking about this issue helped me.
Most of them talk about a ignore laptop lid switch on settings but i couldn't find it.
Other thread suggest that if you have the Zorin Lite you can use this command :
xfconf-query -c xfce4-power-manager -p /xfce4-power-manager/logind-handle-lid-switch -s false
wich did work for 3 attempts and later don't.
So what i wanted to share is that if any of those 2 solutions didn't worked for you here is what i did.
- Go to Settings -> Screensaver
- Automatically there will be a pop up window that said "If you reopen your laptop lid, it won't work
" - Inside the pop up window there will be a RESOLVE button, just click it and the problem will be solved.
I hope this tutorial/guide will help a lot of people out, cause i was searching ways to fix it for hours and the fix was very simple actually.
