Forced Logout
Hello! First time attempt at Linux here. I downloaded Zorin onto my new built desktop at the recommendation of a friend, and the installation went well. However, about a minute after my first login, I was forced back to the login screen. Every time now feels shorter and now I only get about 5-10 seconds after logging in before I get kicked, all the programs close, and I have to log in again.
I disabled the need for multiple logins during setup, but this doesn't seem to have affected anything.
Any advice would be well appreciated.
  • Is Your BIOS in UEFI or Legacy Mode?
  • What Tool did You use to create the Bootstick?
  • Did You checked the Checksum of the ISO?
  • Did You set up Auto Login?
  • Does Your System run in Wayland or X11? When on the Login Screen, click on Your Profile so that the Password Field appears. then, You should see a Gear Icon in the bottom right Corner. Click on it and see what is selected.
