Buongiorno, non riesco a formattare il dvd inserito nel cd-rom atapi perchè compare questo messaggio: "error wiping device:Failed to open the device '/dev/srC/iudisks-error-quark, 0)
grazie
TRANSLATION:
Good morning, I can't format the dvd inserted in the atapi cd-rom because this message appears: “error wiping device:Failed to open the device '/dev/srC/iudisks-error-quark, 0)
thanks
If you are using a CD-ROM drive you will never be able to burn a DVD! Ypu need a DVD-RW drive to do this.
Se si utilizza un'unità CD-ROM non sarà mai possibile masterizzare un DVD! Per farlo è necessaria un'unità DVD-RW.
When I try to format the dvd-rw this message appears: error synchronizing after initial wipe: timed out waiting for object (udisks-error-quark,0)...what to do to solve?...Thank you for your courtesy, Annamaria
Is it Bresero you are using. Try see if k3b do the same.
Dvd-wipe Timeout Error
The error message "Error synchronizing after initial wipe: Timed out waiting for object (udisks-error-quark, 0)" typically occurs when trying to format a disk using the disk utility, and it indicates a timeout issue during the wiping process.234 This error has been reported as a bug and can be mitigated by using alternative tools such as GParted to format the disk.2
To work around this issue, you can follow these steps:
- Install GParted if it is not already installed by opening a terminal and running the appropriate installation command.
- Open GParted and ensure you have selected the correct drive.
- Unmount the disk by right-clicking on the partition and choosing "Unmount".
- Use the "Format To" option to format the disk to your desired file system.
- Apply the changes by clicking the green check mark.
Additionally, some users have reported success by first formatting the disk using another operating system's disk utility, such as Mac OS X's Disk Utility, before attempting to format it on Ubuntu.2
bugs.launchpad.net
Bug #1059872 “Error formatting disk using disk utility” : Bugs ...
askubuntu.com
startup - Unable to format USB drive with Disks (udisks-error-quark, 0) - Ask Ubuntu
forums.linuxmint.com
Error formatting disk: (udisks-error-quark, 0)
unix.stackexchange.com
filesystems - (udisks-error-
Hello, I downloaded K3b zorin os package and I was able to format the dvd-rw immediately.... Thanks for the advice, have a good life... Annamaria
Hello, downloading K3b I managed to format the dvd... Thank you for your availability and have a nice day... Annamaria
Just to add K3b is a great piece of software as it automatically generates an md5 checksum when burning .isos, although most distros these days use SHA checkdums. So make sure to install GtkHash application. I found that righthclicking an .iso to burn using Brasero would create instant coasters. You always have to launch Brasero first before burning.
