Formatting Hard Drive Partition After Zorin 18 Installation
Hello Guys,
I'm new to Zorin 18, after the installation of Zorin 18, I'm unable to format the hardrive into multiple partitions(just like windows) to store my data. Please guide me how to do it.I tried Gparted in zorin 18 but not working. I've enclosed screenshot for reference.
You can use GParted but only from the USB Stick in Live Mode. From Your installed System, You can't make that because it is in Use. It is locked (You can see the little Key Icon beneath sda3). So, take Your Zorin Bootstick, start it and choose ''Try Zorin'' to get in Live Mode. There search for GParted and then You can set up the PArtitions.
Thank you for the support, I've done as per the instructions and formatted the drives into multiple partitions but I'm not able to read or write anything on it. I've attached the screenshot for reference.
Can you please help?
Can You open ''GParted'' and ''Disks'' to show Infos about the Drive and the Partitions please?
