hi there,
I have two monitors 4k 27" and HD 24" so I did set up a fractional scaling. Since the I noticed few issues. The VirtualBox app doesn't display any GUI elements inside the main window.
VLC doesn't display any video but I can hear audio.
The default video app does display everything correctly as long as it's not in full screen mode. When I go to full screen mode the app is moved into my second screen and resolution/scaling is changed.
All the problems are gone when I turn off fractional scaling.
System: Host: l080-PC Kernel: 5.11.0-34-generic x86_64 bits: 64 compiler: N/A
Desktop: Gnome 3.38.4 Distro: Zorin OS 16 base: Ubuntu 20.04 LTS Focal
Machine: Type: Desktop Mobo: Micro-Star model: Z490-A PRO (MS-7C75) v: 1.0
serial: <superuser/root required> UEFI: American Megatrends v: 2.90 date: 04/20/2021
CPU: Topology: 10-Core model: Intel Core i9-10850K bits: 64 type: MT MCP arch: N/A
L2 cache: 20.0 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 144000
Speed: 896 MHz min/max: 800/5200 MHz Core speeds (MHz): 1: 931 2: 4514 3: 3356
4: 2042 5: 1384 6: 1121 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 13: 800 14: 800
15: 800 16: 800 17: 800 18: 2249 19: 3769 20: 2441
Graphics: Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Sapphire Limited Nitro+ driver: amdgpu v: kernel bus ID: 01:00.0
Display: x11 server: X.Org 1.20.11 driver: amdgpu
resolution: 1920x1080~60Hz, 3840x2160~60Hz
OpenGL:
renderer: Radeon RX 580 Series (POLARIS10 DRM 3.40.0 5.11.0-34-generic LLVM 12.0.1)
v: 4.6 Mesa 21.3.0-devel (git-fb5deb2 2021-09-10 focal-oibaf-ppa) direct render: Yes
Audio: Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus ID: 00:1f.3
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Sapphire Limited driver: snd_hda_intel v: kernel bus ID: 01:00.1
Device-3: Corsair type: USB driver: hid-generic,snd-usb-audio,usbhid bus ID: 1-1.4:11
Sound Server: ALSA v: k5.11.0-34-generic
Network: Device-1: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169 v: kernel
port: 3000 bus ID: 04:00.0
IF: enp4s0 state: down mac: d8:bb:c1:11:2a:46
Device-2: Intel Wireless 8260 driver: iwlwifi v: kernel port: 3000 bus ID: 05:00.0
IF: wlp5s0 state: up mac: f4:8c:50:42:67:79
Drives: Local Storage: total: 4.55 TiB used: 383.88 GiB (8.2%)
ID-1: /dev/nvme0n1 vendor: Crucial model: CT500P2SSD8 size: 465.76 GiB
ID-2: /dev/nvme1n1 vendor: Samsung model: SSD 980 PRO 1TB size: 931.51 GiB
ID-3: /dev/sda vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB
ID-4: /dev/sdb vendor: Crucial model: CT2000MX500SSD1 size: 1.82 TiB
Partition: ID-1: / size: 227.98 GiB used: 62.95 GiB (27.6%) fs: ext4 dev: /dev/nvme0n1p2
Sensors: System Temperatures: cpu: 52.0 C mobo: N/A gpu: amdgpu temp: 47 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 763
Info: Processes: 414 Uptime: 22h 20m Memory: 31.28 GiB used: 5.21 GiB (16.7%) Init: systemd
runlevel: 5 Compilers: gcc: 9.3.0 Shell: bash v: 5.0.17 inxi: 3.0.38
Thanks for any help
