Hi i just install zorin 17 core in my razer blade 14 (7700HQ), the issue is every time my computer suspend long enough i cannot login and everything not works (no cursor and keyboard feedback), can you suggest what i need to do? my computer dual boot with windows 11. Thanks
Which graphics driver are you using for your Nvidia 1060?
You can check in Software & Updates
> Additional Drivers
