Freeze by connecting external display via HDMI
Hi,
I just installed Zorin for the first time and upon trying to connect my Lenovo display via HDMI the whole system, while nothing disappears, everything freezes. I cant move the mouse. The second screen shows the background image though nothing else.
The OS is up to date as of today.
I have a ThinkPad T480s
Any ideas how I can fix the issue?
sudo lshw -C video
*-display
product: UHD Graphics 620
vendor: Intel Corporation
physical id: 2
bus info: pci@0000:00:02.0
logical name: /dev/fb0
version: 07
width: 64 bits
clock: 33MHz
capabilities: pciexpress msi pm vga_controller bus_master cap_list rom fb
configuration: depth=32 driver=i915 latency=0 resolution=2560,1440
resources: irq:165 memory:eb000000-ebffffff memory:a0000000-afffffff ioport:e000(size=64) memory:c0000-dffff
When you just have installed Zorin, please take a Look in Settings>About if Your System runs in wayland or X11. When it runs in Wayland, try it with switching to X11/Xorg.
To do that, go to the Login Screen (not the Lock Screen). Simply reboot for that. On the Login Screen click on Your Profile so that the Password Field appears. When it is appeared, You should see in the bottom right Corner a Gear Icon. Click on it and choose the Option ''Zorin Desktop on Xorg'' and then log in.
Then, You should take a Look in Settings>Displays to set up Your Monitor Setup with the now 2 Monitors.
(1) Agreed, please use Xorg.
This picture from the net
(2) If you don't have an Nvidia GPU, you can setup your monitors in Settings Display.
(3) If you do have an Nvidia GPU, please setup your monitors with Nvidia X Server Settings APP, as its far better IMO.
Thank you both for your suggestions.
I did manage to switch to Xorg and it helps with the monitor connection problem, however the whole system becomes extremely laggy and slow, like when all resources are fully exhausted and even moving a window around is slow. Thats why I had to change it back to the original state. Any ideas what I could do to change that behavior?
What are Your System Specs?
And when that happened, did You take a Look in the System Monitor if there is one or several Processes that cause that?
I have a T480s from 2018. Intel Core i5-8250U and UHD Graphics 620. Do you need other specs? I can look it up.
There was nothing else that I noticed particularly heavy on the resources. Thats why I found it strange. But it could have also been that I didnt look deep enough into it. How can i provide more info on that, that would help?
Yes, RAM and the Clockspeed of the CPU would be nice.
You could simply switch again to Xorg and then start the System Monitor.
1,6 GHz
8 GB DDR4
The 8 Gig's of RAM should be enough, but the 1,6Ghz could maybe a bit less. Did You thought about using Zorin Lite instead of Core?
Zorin Lite uses the xfce Desktop Envirronment as Base and is more Ressource-friendly than Zorin Core with the Gnome Desktop as Base.
