DonT
March 6, 2026, 11:10am
1
Hi there,
[EDIT] After some time using Zorin with X11 I actually faced the graphics freeze again. So it isn't a Wayland issue
I've been using Zorin Core for a month or more and was quite happy. I admit I didn't heavily use the Laptop, but for sure I had no issues.
Since I liked Zorin I purchased Zorin Pro and upgrade, presumably this upgrade also installed Zorin 18?
Now I frequently run into kernel freeze or system freeze after a few minutes uptime. Sometimes there's a pink screen with kernel freeze, sometimes the system just hangs after a small graphic hickup. Only a hard reset works after either of the issues.
Reading several posts here I tried booting into Kernel 6.14 again but this had a freeze as well.
Also, I installed the broadcom DKMS package as recommended in one of the posts, this didn't make a difference.
Then I switched to X11 as also suggested, this solved all issues which is great.
But, I have several questions:
It seems that under X11 the UI behaves a little more stuttering. For example when minimizing/maximizing windows it isn't not that smooth as on Wayland. Is this known? Any chance this can be configured?
Is there a setting that allows Wayland to be used but the crashes don't happen? Or is the only solution to completely switch to X11? I believe it was working nicely before I upgraded to Zorin Pro / 18.
How can I actually select the kernel version? At boot there is only the Zorin logo but no chance to select another kernel (not sure how I once did it :-))
Thanks for any help.
Thomas.
DonT
March 6, 2026, 3:56pm
3
Thanks for your response. Here's my feedback:
Secure Boot was disabled
Fast Boot I think is called "Quick" in Lenovo BIOS? It was on Quick and I changed it now to "Diagnostics". Please see attached sceenshot if this is the correct setting?
Windows is not installed on the laptop. I only boot Windows sometimes through an external USB SDD. I am not sure Fast Start-up is disabled there.
Below is the output from the two commands:
thomas@thomas-thinkpad:~$ sudo lshw -C network
[sudo] password for thomas:
*-network:0
product: Meteor Lake PCH CNVi WiFi
vendor: Intel Corporation
physical id: 14.3
bus info: pci@0000:00:14.3
logical name: wlp0s20f3
version: 20
serial: ec:4c:8c:8c:96:d7
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=iwlwifi driverversion=6.17.0-14-generic firmware=89.1a492d28.0 ma-b0-gf-a0-89.uc ip=192.168.2.150 latency=0 link=yes multicast=yes wireless=IEEE 802.11
resources: iomemory:400-3ff irq:18 memory:405a704000-405a707fff
*-network:1
product: Intel Corporation
physical id: 1f.6
bus info: pci@0000:00:1f.6
logical name: enp0s31f6
version: 20
serial: c4:ef:bb:b0:ba:1b
capacity: 1Gbit/s
width: 32 bits
clock: 33MHz
capabilities: pm msi bus_master cap_list ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=e1000e driverversion=6.17.0-14-generic firmware=1.1-4 latency=0 link=no multicast=yes port=twisted pair
resources: irq:156 memory:ab700000-ab71ffff
thomas@thomas-thinkpad:~$ rfkill list
0: tpacpi_bluetooth_sw: Bluetooth
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: no
Hard blocked: no
2: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
No, this isn't what I meant but maybe Your BIOS doesn't have this Option.
You need an active GRUB Menu. You can get it with pressing Esc or the left shift Key during Start-Up but it can be that it doesn't work.
But You can activate it. Open the Terminal and type sudo nano /ect/default/grub and You can edit the GRUB Config File. There is a white Textblock:
You have to change the Lines 2 and 3 to:
GRUB_TIMEOUT_STYLE=menu
and
GRUB_TIMEOUT=20
The last one makes that the GRUB Menu appears 20 Seconds. If that shouldn't be enough Time for You, You can increase it if you want with a higher Number.
When You have done the Changes press ctrl+o to save, Enter to confirm and ctrl+x to exit. Back in the normal Terminal Overview type sudo update-grub to make the Changes affect. Don't forget that! Without it, it will not work.
When You then reboot, You should get the GRUB Menu. choose there ''Advanced Options'' and then choose the Option with the 6.14 Kernel.
But You don't have a Broadcom Chip as far as I can see. Was this offered on the ''Additional Drivers'' Tab in Software & Updates?
DonT
March 7, 2026, 3:35pm
5
I've now been able to boot into the previous kernel but still get a freeze / kernel panic there.
So to summarize:
* Fatal issue with kernel 6.14 and 6.17
* Fatal issue with Wayland and Xorg
"Fatal issue" can be described as this:
- Usually it happens 1 - 5 minutes after boot.
- Sometimes the pink kernel panic screen appears.
- Sometimes the GUI including mouse cursor freezes.
- Sometimes the GUI freezes while the mouse can still be moved but no clicking or keyboard reaction.
In all cases only a hard reset helps to bring the laptop back to life.
As a result, Zorin is not usable for me
Anything else I can provide or try to solve this?
Thanks!
Maybe You will not like what I now ask but I do it: Would You try it with a fresh Installation?
DonT
March 7, 2026, 8:28pm
7
Hehe, actually that's OK because this laptop was not used heavily yet and there's no data on it. So I'm OK doing a fresh install.
Will let you know how this goes.
Thanks!
DonT
March 8, 2026, 10:36am
8
OK, done. Formatted SSD and installed fresh Zorin 18 Pro with minimal packages. I'll see how it goes and will let you know.
DonT
March 8, 2026, 10:48am
9
Just had freeze again
Any other idea or logs I can provide?
Forpli
March 8, 2026, 10:58am
10
What is the brand/model of your computer? What are the specs?
DonT
March 8, 2026, 10:59am
11
BTW; just a side note: While writing the latest ISO Image to my USB drive I realized that I already had v18 on it and installed on this laptop. So my upgrade was not from 17 to 18 Pro as I mentioned at the beginning of this thread, but most likely from 18 to 18 Pro.
Anyway, I had not much used Zorin on this laptop prior to upgrading to 18 Pro, but definitely played some Windows Games (wine/lutris) on it for a few hours without issues.
Okay, could You post Your Hardware Specs? I mean CPU, GPU, RAM etc.
DonT
March 8, 2026, 11:01am
14
$ lspci
00:00.0 Host bridge: Intel Corporation Device 7d14 (rev 04)
00:02.0 VGA compatible controller: Intel Corporation Meteor Lake-P [Intel Arc Graphics] (rev 08)
00:04.0 Signal processing controller: Intel Corporation Device 7d03 (rev 04)
00:06.0 PCI bridge: Intel Corporation Device 7e4d (rev 20)
00:06.2 PCI bridge: Intel Corporation Device 7ecb (rev 10)
00:07.0 PCI bridge: Intel Corporation Meteor Lake-P Thunderbolt 4 PCI Express Root Port #0 (rev 02)
00:07.2 PCI bridge: Intel Corporation Meteor Lake-P Thunderbolt 4 PCI Express Root Port #2 (rev 02)
00:0a.0 Signal processing controller: Intel Corporation Device 7d0d (rev 01)
00:0b.0 Processing accelerators: Intel Corporation Meteor Lake NPU (rev 04)
00:0d.0 USB controller: Intel Corporation Meteor Lake-P Thunderbolt 4 USB Controller (rev 02)
00:0d.2 USB controller: Intel Corporation Meteor Lake-P Thunderbolt 4 NHI #0 (rev 02)
00:0d.3 USB controller: Intel Corporation Meteor Lake-P Thunderbolt 4 NHI #1 (rev 02)
00:14.0 USB controller: Intel Corporation Meteor Lake-P USB 3.2 Gen 2x1 xHCI Host Controller (rev 20)
00:14.2 RAM memory: Intel Corporation Device 7e7f (rev 20)
00:14.3 Network controller: Intel Corporation Meteor Lake PCH CNVi WiFi (rev 20)
00:15.0 Serial bus controller: Intel Corporation Meteor Lake-P Serial IO I2C Controller #0 (rev 20)
00:16.0 Communication controller: Intel Corporation Device 7e70 (rev 20)
00:1c.0 PCI bridge: Intel Corporation Device 7e38 (rev 20)
00:1f.0 ISA bridge: Intel Corporation Device 7e02 (rev 20)
00:1f.3 Audio device: Intel Corporation Meteor Lake-P HD Audio Controller (rev 20)
00:1f.4 SMBus: Intel Corporation Meteor Lake-P SMBus Controller (rev 20)
00:1f.5 Serial bus controller: Intel Corporation Meteor Lake-P SPI Controller (rev 20)
00:1f.6 Ethernet controller: Intel Corporation Device 550b (rev 20)
04:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller PM9C1a
And what Graphics Card You have? If Nvidia: What driver do You use?
DonT
March 8, 2026, 11:20am
16
Using the builtin "Intel ARC graphics":
$ lspci | grep VGA
Hmm ... Normally, I would suggest to switch to X11/Xorg now but You already ahd used that ...
There would be the Option to try it with a newer Kernel. Maybe it offers better Hardware Support. You could try that. Instructions for installing a newer Kernel, You can find here:
Updated as of Mar 28 2025
To install the Mainline Installer:
add the repository:
sudo add-apt-repository ppa:cappelikan/ppa
Update sources and install:
sudo apt update && sudo apt install mainline
Launch Mainline from App Menu or terminal, and select the kernel you wish to test.
To use TuxInvader Kernel:
These are not Microsoft signed, so Secure Boot must be disabled in BIOS Settings.
Add repository:
If using Zorin OS 16:
sudo add-apt-repository ppa:tuxinvader/lts-mainline
If usi…
DonT
March 8, 2026, 11:35am
18
OK, I didn't try Xorg after the fresh installation yet. I will do this now.
If I get a freeze or kernel panic again, I'll try the later kernel path.
Thanks, I will let you know.
DonT
March 8, 2026, 11:41am
19
Just in case I post the last boot messages before kernel panic from the journal P4 and P3 only. Not sure this is of any help.
Mär 08 12:14:54 thomas-ThinkPad kernel: spi-nor spi0.0: unrecognized JEDEC id bytes: f7 f0 30 09 03 00
Mär 08 12:14:55 thomas-ThinkPad kernel: iwlwifi 0000:00:14.3: Not valid error log pointer 0x0024B5C0 for RT uCode
Mär 08 12:14:56 thomas-ThinkPad kernel: iwlwifi 0000:00:14.3: Not valid error log pointer 0x0024B5C0 for RT uCode
Mär 08 12:14:56 thomas-ThinkPad bluetoothd[802]: profiles/sap/server.c:sap_server_register() Sap driver initialization failed.
Mär 08 12:14:56 thomas-ThinkPad bluetoothd[802]: sap-server: Operation not permitted (1)
Mär 08 12:18:04 thomas-ThinkPad gdm-password][1813]: gkr-pam: unable to locate daemon control file
Mär 08 12:18:04 thomas-ThinkPad gdm3[1179]: Gdm: on_display_added: assertion 'GDM_IS_REMOTE_DISPLAY (display)' failed
Mär 08 12:18:05 thomas-ThinkPad systemd[1839]: Failed to start app-gnome-gnome\x2dkeyring\x2dpkcs11-2028.scope - Application launched by gnome-session-binary.
Mär 08 12:18:05 thomas-ThinkPad systemd[1839]: Failed to start app-gnome-im\x2dlaunch-2332.scope - Application launched by gnome-session-binary.
Mär 08 12:18:05 thomas-ThinkPad systemd[1839]: Failed to start app-gnome-user\x2ddirs\x2dupdate\x2dgtk-2327.scope - Application launched by gnome-session-binary.
Mär 08 12:18:06 thomas-ThinkPad gdm3[1179]: Gdm: on_display_removed: assertion 'GDM_IS_REMOTE_DISPLAY (display)' failed
Mär 08 12:14:53 thomas-ThinkPad kernel: #2 #4 #5 #7
Mär 08 12:14:53 thomas-ThinkPad kernel: pnp 00:05: disabling [mem 0x00000000-0x00000fff] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit pref]
Mär 08 12:14:53 thomas-ThinkPad kernel: pnp 00:08: disabling [mem 0x000c0000-0x000c3fff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Mär 08 12:14:53 thomas-ThinkPad kernel: pnp 00:08: disabling [mem 0x000c8000-0x000cbfff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Mär 08 12:14:53 thomas-ThinkPad kernel: pnp 00:08: disabling [mem 0x000d0000-0x000d3fff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Mär 08 12:14:53 thomas-ThinkPad kernel: pnp 00:08: disabling [mem 0x000d8000-0x000dbfff] because it overlaps 0000:00:02.0 BAR 6 [mem 0x000c0000-0x000dffff]
Mär 08 12:14:53 thomas-ThinkPad kernel: pnp 00:08: disabling [mem 0x00000000-0x0009ffff] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit pref]
Mär 08 12:14:53 thomas-ThinkPad kernel: pnp 00:08: disabling [mem 0x000c0000-0x000c3fff disabled] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit pref]
Mär 08 12:14:53 thomas-ThinkPad kernel: pnp 00:08: disabling [mem 0x000c8000-0x000cbfff disabled] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit pref]
Mär 08 12:14:53 thomas-ThinkPad kernel: pnp 00:08: disabling [mem 0x000d0000-0x000d3fff disabled] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit pref]
Mär 08 12:14:53 thomas-ThinkPad kernel: pnp 00:08: disabling [mem 0x000d8000-0x000dbfff disabled] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit pref]
Mär 08 12:14:53 thomas-ThinkPad kernel: pnp 00:08: disabling [mem 0x000e0000-0x000e3fff] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit pref]
Mär 08 12:14:53 thomas-ThinkPad kernel: pnp 00:08: disabling [mem 0x000e8000-0x000ebfff] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit pref]
Mär 08 12:14:53 thomas-ThinkPad kernel: pnp 00:08: disabling [mem 0x000f0000-0x000fffff] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit pref]
Mär 08 12:14:53 thomas-ThinkPad kernel: pnp 00:08: disabling [mem 0x00100000-0x8fffffff] because it overlaps 0000:00:02.0 BAR 7 [mem 0x00000000-0x06ffffff 64bit pref]
Mär 08 12:14:54 thomas-ThinkPad kernel: hpet_acpi_add: no address or irqs in _CRS
Mär 08 12:14:54 thomas-ThinkPad kernel: device-mapper: core: CONFIG_IMA_DISABLE_HTABLE is disabled. Duplicate IMA measurements will not be recorded in the IMA log.
Mär 08 12:14:54 thomas-ThinkPad kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
Mär 08 12:14:54 thomas-ThinkPad systemd-journald[399]: File /var/log/journal/0721be0475f44ad4af3b60092a601808/system.journal corrupted or uncleanly shut down, renaming and replacing.
Mär 08 12:14:54 thomas-ThinkPad kernel: resource: resource sanity check: requesting [mem 0x00000000fedc0000-0x00000000fedcffff], which spans more than pnp 00:05 [mem 0xfedc0000-0xfedc7fff]
Mär 08 12:14:54 thomas-ThinkPad kernel: caller igen6_register_mcis+0x4c/0x330 [igen6_edac] mapping multiple BARs
Mär 08 12:14:54 thomas-ThinkPad kernel: intel_pmc_core INT33A1:00: Assuming a default substate order for this platform
Mär 08 12:14:54 thomas-ThinkPad kernel: spi-nor spi0.0: supply vcc not found, using dummy regulator
Mär 08 12:14:54 thomas-ThinkPad systemd-oomd[773]: No swap; memory pressure usage will be degraded
Mär 08 12:14:54 thomas-ThinkPad (uetoothd)[802]: bluetooth.service: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Mär 08 12:14:54 thomas-ThinkPad (cron)[803]: cron.service: Referenced but unset environment variable evaluates to an empty string: EXTRA_OPTS
Mär 08 12:14:54 thomas-ThinkPad thermald[825]: [/sys/devices/platform/thinkpad_acpi/dytc_lapmode] present: Thermald can't run on this platform
Mär 08 12:14:55 thomas-ThinkPad bluetoothd[802]: src/plugin.c:plugin_init() System does not support csip plugin
Mär 08 12:14:55 thomas-ThinkPad bluetoothd[802]: profiles/audio/micp.c:micp_init() D-Bus experimental not enabled
Mär 08 12:14:55 thomas-ThinkPad bluetoothd[802]: src/plugin.c:plugin_init() System does not support micp plugin
Mär 08 12:14:55 thomas-ThinkPad bluetoothd[802]: src/plugin.c:plugin_init() System does not support vcp plugin
Mär 08 12:14:55 thomas-ThinkPad bluetoothd[802]: src/plugin.c:plugin_init() System does not support mcp plugin
Mär 08 12:14:55 thomas-ThinkPad bluetoothd[802]: src/plugin.c:plugin_init() System does not support bass plugin
Mär 08 12:14:55 thomas-ThinkPad bluetoothd[802]: src/plugin.c:plugin_init() System does not support bap plugin
Mär 08 12:14:55 thomas-ThinkPad gnome-remote-de[807]: Init TPM credentials failed because Failed to initialize transmission interface context: tcti:IO failure, using GKeyFile as fallback
Mär 08 12:14:55 thomas-ThinkPad kernel: nvme nvme0: using unchecked data buffer
Mär 08 12:14:55 thomas-ThinkPad boltd[940]: [fad38780-409a-domain0 ] udev: failed to determine if uid is stable: unknown NHI PCI id '0x7ec2'
Mär 08 12:14:55 thomas-ThinkPad boltd[940]: [62438780-e147-domain1 ] udev: failed to determine if uid is stable: unknown NHI PCI id '0x7ec3'
Mär 08 12:14:55 thomas-ThinkPad kernel: skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
Mär 08 12:14:55 thomas-ThinkPad kernel: skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
Mär 08 12:14:55 thomas-ThinkPad generate[1063]: Permissions for /lib/netplan/00-network-manager-all.yaml are too open. Netplan configuration should NOT be accessible by others.
Mär 08 12:14:59 thomas-ThinkPad pipewire[1217]: mod.jackdbus-detect: Failed to receive jackdbus reply: org.freedesktop.DBus.Error.ServiceUnknown: The name org.jackaudio.service was not provided by any .service files
Mär 08 12:14:59 thomas-ThinkPad /usr/libexec/gdm-wayland-session[1236]: dbus-daemon[1236]: [session uid=121 pid=1236] Activating service name='org.freedesktop.systemd1' requested by ':1.2' (uid=121 pid=1240 comm="/usr/libexec/gnome-session-binary --autostart /usr" label="unconfined")
Mär 08 12:14:59 thomas-ThinkPad /usr/libexec/gdm-wayland-session[1236]: dbus-daemon[1236]: [session uid=121 pid=1236] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
Mär 08 12:14:59 thomas-ThinkPad gnome-session-binary[1240]: WARNING: Could not check if unit gnome-session-wayland@gnome-login.target is active: Error calling StartServiceByName for org.freedesktop.systemd1: Process org.freedesktop.systemd1 exited with status 1
Mär 08 12:14:59 thomas-ThinkPad wireplumber[1219]: Failed to get percentage from UPower: org.freedesktop.DBus.Error.NameHasNoOwner
Mär 08 12:15:00 thomas-ThinkPad /usr/libexec/gdm-wayland-session[1236]: dbus-daemon[1236]: [session uid=121 pid=1236] Activating service name='org.a11y.Bus' requested by ':1.4' (uid=121 pid=1271 comm="/usr/bin/gnome-shell" label="unconfined")
Mär 08 12:15:00 thomas-ThinkPad /usr/libexec/gdm-wayland-session[1236]: dbus-daemon[1236]: [session uid=121 pid=1236] Successfully activated service 'org.a11y.Bus'
Mär 08 12:15:00 thomas-ThinkPad wireplumber[1219]: <WpPortalPermissionStorePlugin:0x5d7a3c94aa20> Failed to call Lookup: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for camera
Mär 08 12:15:00 thomas-ThinkPad /usr/libexec/gdm-wayland-session[1344]: dbus-daemon[1344]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=121 pid=1271 comm="/usr/bin/gnome-shell" label="unconfined")
Mär 08 12:15:00 thomas-ThinkPad /usr/libexec/gdm-wayland-session[1344]: dbus-daemon[1344]: Successfully activated service 'org.a11y.atspi.Registry'
Mär 08 12:15:00 thomas-ThinkPad /usr/libexec/gdm-wayland-session[1236]: dbus-daemon[1236]: [session uid=121 pid=1236] Activating service name='org.gnome.Shell.Screencast' requested by ':1.3' (uid=121 pid=1271 comm="/usr/bin/gnome-shell" label="unconfined")
Mär 08 12:15:00 thomas-ThinkPad /usr/libexec/gdm-wayland-session[1236]: dbus-daemon[1236]: [session uid=121 pid=1236] Activating service name='org.freedesktop.impl.portal.PermissionStore' requested by ':1.3' (uid=121 pid=1271 comm="/usr/bin/gnome-shell" label="unconfined")
Mär 08 12:15:00 thomas-ThinkPad /usr/libexec/gdm-wayland-session[1236]: dbus-daemon[1236]: [session uid=121 pid=1236] Successfully activated service 'org.freedesktop.impl.portal.PermissionStore'
Mär 08 12:15:00 thomas-ThinkPad /usr/libexec/gdm-wayland-session[1236]: dbus-daemon[1236]: [session uid=121 pid=1236] Activating service name='org.gnome.Shell.Notifications' requested by ':1.3' (uid=121 pid=1271 comm="/usr/bin/gnome-shell" label="unconfined")
Mär 08 12:15:00 thomas-ThinkPad /usr/libexec/gdm-wayland-session[1236]: dbus-daemon[1236]: [session uid=121 pid=1236] Successfully activated service 'org.gnome.Shell.Notifications'
Mär 08 12:15:00 thomas-ThinkPad /usr/libexec/gdm-wayland-session[1236]: dbus-daemon[1236]: [session uid=121 pid=1236] Activating service name='org.freedesktop.systemd1' requested by ':1.9' (uid=121 pid=1407 comm="/usr/libexec/gsd-sharing" label="unconfined")
Mär 08 12:15:00 thomas-ThinkPad /usr/libexec/gdm-wayland-session[1236]: dbus-daemon[1236]: [session uid=121 pid=1236] Activated service 'org.freedesktop.systemd1' failed: Process org.freedesktop.systemd1 exited with status 1
Mär 08 12:15:00 thomas-ThinkPad gsd-sharing[1407]: Failed to StopUnit service: GDBus.Error:org.freedesktop.DBus.Error.Spawn.ChildExited: Process org.freedesktop.systemd1 exited with status 1
Mär 08 12:15:00 thomas-ThinkPad /usr/libexec/gdm-wayland-session[1236]: dbus-daemon[1236]: [session uid=121 pid=1236] Activating service name='org.freedesktop.portal.IBus' requested by ':1.24' (uid=121 pid=1514 comm="ibus-daemon --panel disable" label="unconfined")
Mär 08 12:15:00 thomas-ThinkPad /usr/libexec/gdm-wayland-session[1236]: dbus-daemon[1236]: [session uid=121 pid=1236] Successfully activated service 'org.freedesktop.portal.IBus'
Mär 08 12:15:00 thomas-ThinkPad gnome-shell[1271]: Trying to set label on QuickToggle. Use title instead.
Mär 08 12:15:01 thomas-ThinkPad /usr/libexec/gdm-wayland-session[1236]: dbus-daemon[1236]: [session uid=121 pid=1236] Successfully activated service 'org.gnome.Shell.Screencast'
Mär 08 12:15:01 thomas-ThinkPad gsd-media-keys[1430]: Failed to grab accelerator for keybinding settings:playback-repeat
Mär 08 12:15:01 thomas-ThinkPad gsd-media-keys[1430]: Failed to grab accelerator for keybinding settings:hibernate
Mär 08 12:15:01 thomas-ThinkPad /usr/libexec/gdm-wayland-session[1236]: dbus-daemon[1236]: [session uid=121 pid=1236] Activating service name='org.gnome.ScreenSaver' requested by ':1.22' (uid=121 pid=1474 comm="/usr/libexec/gsd-power" label="unconfined")
Mär 08 12:15:01 thomas-ThinkPad /usr/libexec/gdm-wayland-session[1236]: dbus-daemon[1236]: [session uid=121 pid=1236] Successfully activated service 'org.gnome.ScreenSaver'
Mär 08 12:15:01 thomas-ThinkPad /usr/libexec/gdm-wayland-session[1236]: dbus-daemon[1236]: [session uid=121 pid=1236] Activating service name='org.freedesktop.portal.IBus' requested by ':1.34' (uid=121 pid=1668 comm="ibus-daemon --panel disable -r --xim" label="unconfined")
Mär 08 12:15:01 thomas-ThinkPad /usr/libexec/gdm-wayland-session[1236]: dbus-daemon[1236]: [session uid=121 pid=1236] Successfully activated service 'org.freedesktop.portal.IBus'
Mär 08 12:15:01 thomas-ThinkPad systemd[1]: kerneloops.service: Found left-over process 1729 (kerneloops) in control group while starting unit. Ignoring.
Mär 08 12:15:01 thomas-ThinkPad systemd[1]: kerneloops.service: This usually indicates unclean termination of a previous run, or service implementation deficiencies.
Mär 08 12:15:01 thomas-ThinkPad (rneloops)[1730]: kerneloops.service: Referenced but unset environment variable evaluates to an empty string: DAEMON_ARGS
Mär 08 12:18:01 thomas-ThinkPad gdm-fingerprint][1814]: gkr-pam: no password is available for user
Mär 08 12:18:04 thomas-ThinkPad pipewire[1860]: mod.jackdbus-detect: Failed to receive jackdbus reply: org.freedesktop.DBus.Error.ServiceUnknown: The name org.jackaudio.service was not provided by any .service files
Mär 08 12:18:04 thomas-ThinkPad gsd-media-keys[1430]: Unable to get default sink
Mär 08 12:18:04 thomas-ThinkPad gsd-media-keys[1430]: Unable to get default source
Mär 08 12:18:05 thomas-ThinkPad gnome-keyring-daemon[2039]: discover_other_daemon: 1
Mär 08 12:18:05 thomas-ThinkPad systemd[1839]: app-gnome-gnome\x2dkeyring\x2dpkcs11-2028.scope: No PIDs left to attach to the scope's control group, refusing.
Mär 08 12:18:05 thomas-ThinkPad systemd[1839]: app-gnome-gnome\x2dkeyring\x2dpkcs11-2028.scope: Failed with result 'resources'.
Mär 08 12:18:05 thomas-ThinkPad gnome-keyring-daemon[2040]: discover_other_daemon: 1
Mär 08 12:18:05 thomas-ThinkPad gnome-keyring-daemon[2042]: discover_other_daemon: 1
Mär 08 12:18:05 thomas-ThinkPad wireplumber[1863]: <WpPortalPermissionStorePlugin:0x61532d985c50> Failed to call Lookup: GDBus.Error:org.freedesktop.portal.Error.NotFound: No entry for camera
Mär 08 12:18:05 thomas-ThinkPad systemd[1839]: Dependency failed for org.gnome.SettingsDaemon.XSettings.service - GNOME XSettings service.
Mär 08 12:18:05 thomas-ThinkPad gnome-session-binary[2007]: GnomeDesktop-WARNING: Could not create transient scope for PID 2212: GDBus.Error:org.freedesktop.DBus.Error.UnixProcessIdUnknown: Failed to set unit properties: No such process
Mär 08 12:18:05 thomas-ThinkPad at-spi2-registr[2129]: Failed to register client: GDBus.Error:org.gnome.SessionManager.AlreadyRegistered: Unable to register client
Mär 08 12:18:05 thomas-ThinkPad at-spi2-registr[2129]: Unable to register client with session manager
Mär 08 12:18:05 thomas-ThinkPad systemd[1839]: app-gnome-im\x2dlaunch-2332.scope: Failed to add PIDs to scope's control group: No such process
Mär 08 12:18:05 thomas-ThinkPad systemd[1839]: app-gnome-im\x2dlaunch-2332.scope: Failed with result 'resources'.
Mär 08 12:18:05 thomas-ThinkPad systemd[1839]: app-gnome-user\x2ddirs\x2dupdate\x2dgtk-2327.scope: No PIDs left to attach to the scope's control group, refusing.
Mär 08 12:18:05 thomas-ThinkPad systemd[1839]: app-gnome-user\x2ddirs\x2dupdate\x2dgtk-2327.scope: Failed with result 'resources'.
Mär 08 12:18:05 thomas-ThinkPad gnome-shell[2046]: Gio.UnixInputStream has been moved to a separate platform-specific library. Please update your code to use GioUnix.InputStream instead.
0 inhibit() ["resource:///org/gnome/shell/misc/loginManager.js":209:8]
1 InterpretGeneratorResume() ["self-hosted":1461:33]
2 AsyncFunctionNext() ["self-hosted":852:26]
3 anonymous() ["resource:///org/gnome/shell/ui/init.js":21:19]
Mär 08 12:18:05 thomas-ThinkPad gnome-shell[2046]: Trying to set label on QuickToggle. Use title instead.
Mär 08 12:18:06 thomas-ThinkPad gsd-media-keys[2196]: Failed to grab accelerator for keybinding settings:playback-repeat
Mär 08 12:18:06 thomas-ThinkPad gsd-media-keys[2196]: Failed to grab accelerator for keybinding settings:hibernate
Mär 08 12:18:06 thomas-ThinkPad gnome-shell[1271]: Connection to xwayland lost
Mär 08 12:18:06 thomas-ThinkPad gnome-shell[1271]: Xwayland terminated, exiting since it was mandatory
Mär 08 12:18:06 thomas-ThinkPad gnome-shell[1271]: (../src/core/meta-context.c:542):meta_context_terminate: runtime check failed: (g_main_loop_is_running (priv->main_loop))
Mär 08 12:18:06 thomas-ThinkPad gnome-shell[1271]: JS ERROR: Gio.IOErrorEnum: Xwayland exited unexpectedly
@resource:///org/gnome/shell/ui/init.js:21:20
Mär 08 12:18:06 thomas-ThinkPad gsd-sharing[1407]: Error releasing name org.gnome.SettingsDaemon.Sharing: The connection is closed
Mär 08 12:18:06 thomas-ThinkPad gsd-smartcard[1420]: Error releasing name org.gnome.SettingsDaemon.Smartcard: The connection is closed
Mär 08 12:18:06 thomas-ThinkPad kernel: kauditd_printk_skb: 122 callbacks suppressed
Mär 08 12:18:16 thomas-ThinkPad systemd[1200]: xdg-permission-store.service: Failed with result 'exit-code'.
Mär 08 12:18:23 thomas-ThinkPad gnome-shell[2046]: meta_window_set_stack_position_no_sync: assertion 'window->stack_position >= 0' failed
Mär 08 12:18:25 thomas-ThinkPad kernel: workqueue: pm_runtime_work hogged CPU for >10000us 4 times, consider switching to WQ_UNBOUND
Mär 08 12:18:33 thomas-ThinkPad kernel: warning: `Socket Thread' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
Mär 08 12:18:44 thomas-ThinkPad gnome-shell[2046]: meta_window_set_stack_position_no_sync: assertion 'window->stack_position >= 0' failed
Mär 08 12:19:31 thomas-ThinkPad kernel: workqueue: pm_runtime_work hogged CPU for >10000us 5 times, consider switching to WQ_UNBOUND
Mär 08 12:19:50 thomas-ThinkPad kernel: workqueue: pm_runtime_work hogged CPU for >10000us 7 times, consider switching to WQ_UNBOUND
DonT
March 8, 2026, 12:02pm
20
Now on the last from the 6.17 line:
$ uname -r
6.17.12-061712-generic
Let's see...
