I have this freezing issue in grub that takes a lot of time to load the Zorin environment and when it's loaded, it freeze's or stuck when clicking apps or the file manager, and if it's totally freeze, I press the power button and restart it once again and at that point, the grub and the Zorin DE got back to its normal flow.
I noticed this issue, after using windows 10 and restarting the laptop to dual-boot in Zorin.
These are some of things that I have done in my linux system and I don't know if these contributes to the problem.
I manually partition the root directory with 30gb in SSD and 200gb in HDD for the home directory. I also added an 8gb swap file size.
I also have installed Xubuntu on my system, but it doesn't face the same issue like Zorin. Unlike Zorin, I partition the Xubuntu's root and home with 50gb in HDD only.
The 8gb swap file is shared with Zorin and Xubuntu
This is my current system configuration
Also, I'm still new at linux system. I tried Zorin OS core but it's kind a slow in my laptop's capability, so I choose the lite version instead. I also, spend some time searching and watching videos in YouTube to solve or just to minimize the issue but no luck at this moment.
Thanks for the help Zorin community!
