Hello, do you know if there is support for the Galaxy Book 5 Pro 360 in the latest versions of Zorin OS? I read that drivers specific to Samsung Galaxy Books had been added to the main branch starting with kernel 6.15. Would you recommend switching to Zorin now, or should I wait a little longer for support for the performance switch, built-in speakers, backlighting and shortcut keys, camera and fingerprint sensor?
Thank you for any helpful advice.
You can take a look at this thread:
You could download Zorin, put it on an USB Stick, start it and choose ''Try Zorin'' to get in the Live Mode. then it runs from the USB Stick. The Performance might not be so well but You can test if it runs and support the Functions You want.
