The box that pops up and counts down from 60 seconds whenever you attempt to log out, shut down or reboot is viewed by some (usually on laptops with their power button in an inconvenient spot on their keyboard, such as right next to the Delete key {hrmmmphhh... HP... hrmmmphhh}) as a god-send, and by others (usually with desktop computers) as a nuisance.
You can disable or enable them.
If you don't use flatpak:
sudo apt install dconf-editor
If you do use flatpak:
flatpak install flathub ca.desrt.dconf-editor
flatpak run ca.desrt.dconf-editor
...wait for dconf-editor to start, then within the application, navigate to:
/org/gnome/gnome-session/
and disable / enable "logout-prompt".
