Hey guys & gals of Zorin OS!
I'm in the process to ditch windows for Linux and chose Zorin OS to be the distro of my choice.
I use Davinci Resolve to edit my YouTube videos and have done so using my Hackintosh in the past. However, I would love to use Linux exclusively and also edit on here.
Well here is the problem you probably already anticipated - Davinci Resolve and Linux are not a match made in heaven to say the least (thx blackmagic) there are ways to install Resolve on Ubuntu which of course Zorin OS is based on - so I have run the "MakeResolveDeb" script and got it installed - however I am constantly running into the "Unsupported GPU Mode" OpenGL Error - meaning Resolve does not recognize that my AMD-GPU supports and uses OpenGL.
I have tried almost every tutorial out there and can confirm that OpenGL is installed and recognized by the system.
I would just wish for someone to give me some kind of tip on what to do and somehow fix this - if this should somehow work - I am ready to finally make the switch ![]()
So here are my specs:
AMD RX 5500 XT
16 GB DDR4 RAM
AMD Ryzen 5 3600
Zorin OS is running on a 480GB SSD as well
Feel free to ask for any logs you may need - I just haven't attached any because there are so many different possibilities to check for OpenGL that I assume its better if you say what exactly you need and I deliver ![]()
Any help is MUCH appreciated!
Thanks, guys & gals!
