Due to recurring network issues I've had in the past over reliability, I decided to spend some money on getting a good USB WIFI adapter. However, I'm a bit lost when it comes to setting up the drivers within Zorin to work accordingly with it.
Information About the Adapter
Brand: tp-link
Model: TL-WN823N
Zorin shows it as a recognised adapter, but I am unable to connect to any networks with it. I am also aware that this model supports Linux, but the instructions I read were complicated and not really helpful if you got stuck somewhere along the process. Any help would be much appreciated!
This has all the files that are linked to the adapter. There’s a Linux beta download for it but I don’t know how to install it so. The manual is also linked on it
cp: cannot stat '88x2bu.ko': No such file or directory
The log of the make command after I ran make clean was the following:
make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/5.13.0-30-generic/build M=/home/jeffrey/Downloads/rtl8192EU_WiFi_linux_v5.2.19.1_25633.20171222_COEX20171113-0047 modules
make[1]: Entering directory '/usr/src/linux-headers-5.13.0-30-generic'
CC [M] /home/jeffrey/Downloads/rtl8192EU_WiFi_linux_v5.2.19.1_25633.20171222_COEX20171113-0047/core/rtw_cmd.o
In file included from /home/jeffrey/Downloads/rtl8192EU_WiFi_linux_v5.2.19.1_25633.20171222_COEX20171113-0047/include/osdep_service.h:47,
from /home/jeffrey/Downloads/rtl8192EU_WiFi_linux_v5.2.19.1_25633.20171222_COEX20171113-0047/include/drv_types.h:27,
from /home/jeffrey/Downloads/rtl8192EU_WiFi_linux_v5.2.19.1_25633.20171222_COEX20171113-0047/core/rtw_cmd.c:17:
/home/jeffrey/Downloads/rtl8192EU_WiFi_linux_v5.2.19.1_25633.20171222_COEX20171113-0047/include/osdep_service_linux.h: In function ‘_init_timer’:
/home/jeffrey/Downloads/rtl8192EU_WiFi_linux_v5.2.19.1_25633.20171222_COEX20171113-0047/include/osdep_service_linux.h:299:8: error: ‘_timer’ {aka ‘struct timer_list’} has no member named ‘data’
299 | ptimer->data = (unsigned long)cntx;
/home/jeffrey/Downloads/rtl8192EU_WiFi_linux_v5.2.19.1_25633.20171222_COEX20171113-0047/include/osdep_service_linux.h:300:2: error: implicit declaration of function ‘init_timer’; did you mean ‘_init_timer’? [-Werror=implicit-function-declaration]
300 | init_timer(ptimer);
| _init_timer
In file included from /home/jeffrey/Downloads/rtl8192EU_WiFi_linux_v5.2.19.1_25633.20171222_COEX20171113-0047/include/drv_types.h:30,
/home/jeffrey/Downloads/rtl8192EU_WiFi_linux_v5.2.19.1_25633.20171222_COEX20171113-0047/include/wifi.h: At top level:
/home/jeffrey/Downloads/rtl8192EU_WiFi_linux_v5.2.19.1_25633.20171222_COEX20171113-0047/include/wifi.h:1031: warning: "IEEE80211_MAX_AMPDU_BUF" redefined
1031 | #define IEEE80211_MAX_AMPDU_BUF 0x40
In file included from /home/jeffrey/Downloads/rtl8192EU_WiFi_linux_v5.2.19.1_25633.20171222_COEX20171113-0047/include/osdep_service_linux.h:83,
./include/linux/ieee80211.h:1657: note: this is the location of the previous definition
1657 | #define IEEE80211_MAX_AMPDU_BUF 0x100
cc1: some warnings being treated as errors
make[2]: *** [scripts/Makefile.build:281: /home/jeffrey/Downloads/rtl8192EU_WiFi_linux_v5.2.19.1_25633.20171222_COEX20171113-0047/core/rtw_cmd.o] Error 1
make[1]: *** [Makefile:1879: /home/jeffrey/Downloads/rtl8192EU_WiFi_linux_v5.2.19.1_25633.20171222_COEX20171113-0047] Error 2
make[1]: Leaving directory '/usr/src/linux-headers-5.13.0-30-generic'
make: *** [Makefile:1828: modules] Error 2
