Getting sound to work
Hello, I am very new to linux.But this is the second linux system I've installed, and I can't get my sound card to work. I've tried everything all the command prompts.Now let's interest because of an eye bring up alsamixer it shows my card as a intel were the setting show it as a Nvidia card so in the alsamixer i tried to set it up as nivida s/pdif i cant get it to change the volume settings how do i change them they are all at zero ive tried cursing up it didn't work ive tried typing it in that didnt work i need help thanks
Can you Post a screenshot of your alsamixer with "All" channels [F5] set.
Also give details of your soundcard/s listed by [F6].
Can you please edit your forum profile, to indicate which ZorinOS edition (e.g. Pro, Core, Lite, Education) you are using. That info will help us help you.
Hi and welcome.
Can you open a Terminal and copy and paste the following command by using the clipboard icon to the right of tholis command?:
lspci -v | grep -i audio
and post back the results please.
(Just to add Zorin 18 tends to identify S/PDIF even though it is not in use (had the same issue in 17) as I have a SoundBlaster Audigy Rx card.
You could try it with Pulse Audio Volume control. It is a Tool for set up Audio Input and Output. You can install it with the Command sudo apt install pavucontrol
When installed, open it and take a Look at the Output Tab and the Configuration Tab.
