Gimp 3 - Cut and new level issue
Hi to All!
I'm Andre and enjoy to use Zorin. Last day i'll take the new Gimp 3, similary to old but with a little problem when i cut and paste a image in another image.
When i do i'll take a new level, and i don't wanna fuse anytime the level. There's an option to come back in old version?
Thx to all and have a nice day!
Andre
Hi Andre, welcome to Zorin OS.
Since this is a problem specific to GIMP, and the latest 3.0 version has just been released, I'd recommend you head over to Gnome community and ask about this over there directly.
Make sure to use the tag to filter and post in the right category:
How did You install Gimp? As Flatpak? If yes, uninstall it and install the Zorin APT Package. That is an older Version. You can install it in the Terminal with the Command:
sudo apt install gimp
or in the Software Store. Search for Gimp, open the Software Site and at the right Side click on the Dropdown Menu under ''Install'' and choose Zorin APT:
The Flatpak version is already at the newest version 3, but not so the one from the default repositories. I don't think this issue is related to the package format, but to the newest version released. Maybe it's a bug, so it's definitely worth to bring it to the attention of the developers (even if it turns out not to be).
There is an AppImage available. Maybe that works properly.
It could be, but even so it's worth reporting this inconsistency to the developers. With new major releases it's common to start seeing bugs appear right away during the early days.
