Just how @Aravisian said about GNOME Boxes, I tried it. When I went to create a VM for Windows XP, it crashes. What’s the problem?
Also, when I went to run Windows Xp VM on virt-manager, it can’t boot. It says, ‘No bootable device selected. I have QEMU installed, and also I have created the VM with ISO in it. What’s the problem?
Hmmm... as you are also currently questioning VmWare in another thread, I think we will focus on that, first.
VmWare is pretty solid, whereas Gnome-Boxes is easy to use but can be... uhh... buggy. It is great when it works.
But VmWare is preferable...
In respect of Virt-Manager, you need to install whatever OS you want to a virtual disc. I get the same issue if I try and run Zorin 17 in live mode without installing - on launching the live iso it can't find the image because it hasn't been installed.
Another point to note about virt-manager is that it saves virtual installed drives in /var and if there is not enough space, it won't for example take additional images. In Devuan 3.1.1. I created a folder called 'storage' for all Virt-Manager virtual hd's.
XP won't run live, so you will have to install it as a Virtual Drive. It's been a while since I used VMWare Player (the free one) and that was only in Windows. I much prefer virt-manager, period.
