gnome-keyring does not autostart in Zorin OS (OnlyShowIn mismatch)
On Zorin OS 17.3 Core, the gnome-keyring daemon does not autostart correctly when logging into the desktop session.
Cause:
  • Zorin sets the desktop identifier as XDG_CURRENT_DESKTOP=zorin:GNOME.
  • The autostart files in /etc/xdg/autostart/gnome-keyring-*.desktop contain:
    OnlyShowIn=GNOME;Unity;MATE;
  • Because of this mismatch, gnome-keyring does not start automatically.
Symptoms:
  • Delay (~20 seconds) when opening a terminal.
  • Errors in logs:
    • gkr-pam: unable to locate daemon control file
    • gkr-pam: couldn't unlock the login keyring
  • Multiple or missing gnome-keyring-daemon processes.
Workaround:
Copy the files to ~/.config/autostart/ and remove the OnlyShowIn line:
mkdir -p ~/.config/autostart
cp /etc/xdg/autostart/gnome-keyring-*.desktop ~/.config/autostart/
sed -i '/^OnlyShowIn=/d' ~/.config/autostart/gnome-keyring-*.desktop
Suggestion:
Please update the .desktop files in Zorin so they either include ZORIN in OnlyShowIn, or remove the line (as in Ubuntu). This would allow gnome-keyring to autostart properly without user intervention.
Environment:
  • Zorin OS 17.3 Core (64-bit)
  • Wayland session
  • Intel Core i7-1360P (13th Gen)
  • 32 GB RAM
  • Mesa Intel Graphics (RPL-P)
  • 500 GB SSD
The definition for the entries "OnlyShowIn" and "NotShowIn" as per the XDG Desktop Entry Specification state:
If $XDG_CURRENT_DESKTOP is set then it contains a colon-separated list of strings. In order, each string is considered.
This means that the desktop files are valid and correctly configured. And I can see that Gnome Keyring does start normally for me without any changes. No delay in launching the terminal, either.
I suspect you may be experiencing a different issue... although the workaround you found is interesting, and possibly related.
