Hi,
When I install Golang using the command: 'sudo apt install golang'
I get the old version of Golang
Reading package lists... Done
Building dependency tree
golang-1.10 golang-1.10-doc golang-1.10-go
golang-1.10-race-detector-runtime golang-1.10-src golang-doc golang-go
golang-race-detector-runtime golang-src
Suggested packages:
bzr mercurial subversion
golang golang-1.10 golang-1.10-doc golang-1.10-go
0 upgraded, 10 newly installed, 0 to remove and 0 not upgraded.
Need to get 42,7 MB of archives.
After this operation, 229 MB of additional disk space will be used.
I need to build projects that require Golang v 1.14 or newer, so I had to download binaries directly from the Golang project page.
Is there any possibility to improve these repositories?
