Grub boot problem
Hi everyone,
I'm new to Linux and recently installed Zorin OS 18.1 on my Lenovo ThinkBook 15-IIL. I'm having a recurring GRUB issue that happens almost every time I reboot.
After rebooting, instead of booting normally, I get dropped into the GRUB command line ( first pricture ) and after i type any command ikm dropped into the command line with dozens of "error: command failed" messages, in the pic i wrote 'normal'
The only workaround I found is to hold the power button to force shutdown, then press it again to boot. Even this doesn't always work on the first try — sometimes I need to do it multiple times before it boots normally.
Once I'm in the system, I can fix it temporarily by running:
sudo grub-install /dev/nvme0n1
sudo update-grub
But the problem comes back after the next reboot.
I've already tried adding GRUB_RECORDFAIL_TIMEOUT=5 to /etc/default/grub but the issue persists.
My setup:
  • Zorin OS 18.1 (Ubuntu 24.04 base)
  • GNOME 46
  • Kernel: 6.17.0-23-generic
  • Boot mode: UEFI / Wayland
  • SSD: WD NVMe 512GB (nvme0n1)
  • External HDD: Seagate 2TB connected via USB
Has anyone experienced this? Any help would be greatly appreciated!
Thank you!
If You still have the Zorin Bootstick, start it and run it in Live Mode. There look for ''Boot Repair'' and let it run.
