Hello Ladies and Gentlemen and especially the Zorin Dev's!
I want suggest to have enabled the GRUB Menu on Startup by default. At the Moment it is only there when You choose the Dual-Boot Installation Option. When You install Zorin only or choose the ''Something else'' Option it is not enabled.
Because of some Experience now with Helping here in the Forum, I think it can be a Benefit when the GRUB Menu is visible by default. Primary when it is neccessary to switch to an older Kernel.
Sure, You can try it with Esc or left Shift Key and when that doesn't work, adjust the GRUB Config File. But when it would be there by default, this wouldn't be neccessary.
Now, You could argue that there will be People who don't want it have enabled. And I'm sure there will be People. But for these, we could set up a Tutorial here in the Forum or the Dev's can make one for the Zorin Help Page (and @swarfendor437 could also bring that up in his unofficial Manual) to guide the People how to disable it.
But in Common, in my Opinion, an enabled GRUB Menu would be a good Idea.
I do have mine on as default with a 5 sec delay in case i need to switch kernels. I hav'nt really had any troubles with the kernel myself, but im on the liquorix kernel and its been awsome. no troubles what so ever
What is interesting to note is that every Debian distribution I have tried so far:
Always boots with GRUB
Defaults to a 5 second delay.
I think it is clearly a Gnome thing who want to be like Microsoft more and more.
You misspelled Microslop.....lol
While Gnome is not in charge of that particular choice, the mentality is the same:
Limit visibility of menu's and options.
Limit user access to tools, functions and features.
Then, begin phasing features out.
Slowly take control over the users system.
Hiding menu's as Gnome does, calling it "minimal" interface, then applying Hard Force using LibAdwaita and the HIG are what Gnome itself is doing.
But Canonical and others are on board with this.
That has nothing to do with Gnome. With a Debian-only Installation, I didn't had a GRUB Menu, too - but this was in the Past. How it is with the current Debian 13, I don't know. When I have it installed, it is still in Dual-Boot with Zorin. And then I have the GRUB from Debian before I change it.
@Ponce-De-Leon That is a really awesome idea, as it would greatly aid troubleshooting computer problems, like needing to revert to an old kernel. I never understood why GRUB doesn't show up, simply because one is not dual booting. Remember, the philosophy is to be better then Windows, not to lock down things, just like them.
That is actually the Point. It would be only one System; so it starts directly through. I mean, I can understand this Point. But I would think that it is be better to have it active. Especially for Troubleshooting.
Perhaps I should have been more clear. I should have stipulated distributions based on Debian; PCLOS Debian and Q4OS - and both have a sensible timeout of 5 seconds.
