grub menu shows up when I boot. How do I get the computer from doing this? I've installed zorin 18 and also have partitions with zorin 17.3 in it.
If you are dual booting, then it must show so you can select what O.S. you are trying to boot into.
If you do not want the grub menu and want to remove Zorin OS 17, that is an option.
Hello Cardiffsurfer, I had a simular issue while creating a USB of ZorinOS-18 from one USB to USB, after install it said said I must reboot and I think it borked up the main PC-ZorinOS-boot, as I had same screen you described upon returning to MAIN-OS. My fix was to plug the bootable USB-ZorinOS-Image-Drive back in, then boot to TRY mode, open Terminal and type simply " boot-repair " choose auto. Then afterwards reboot without USB and all good. Hope this helps you & any others with the Black Grub Menu. Have a Happy Linux day ![]()
You could remove Zorin 17 and then disable GRUB. Or - if You want keep Z17 for now - You could at least reduce the Time the GRUB Menu appears.
Thanks!
Thanks
Remember, the grub menu comes in handy if you get a kernel update that plays naughty and you need "Additional Options for Zorin" from grub menu to choose a previous working kernel. Just saying. Zab.
This is probably off topic but 10 secs on the Zorin grub menu is overkill.
The minimal should be 5 secs.
I have mine set at 3 secs.
I think this is nitpicking.
Imagine, You set it to -1 ...
It takes me 10-seconds to eat my grubs, so I keep mine set to 10-seconds, so I have time to have my grub eating fingers free, so that I may hit the enter key when ready.
Set it at 10 and hit enter as soon as you are ready to short circuit the rest of the wait time.
It should be an instant boot? Not even giving time for the Zorin logo to pop up.
When You set it to -1, it is the Oppsite. The GRUB Menu stands until the User makes an Input.
I did not know that and I thank you for that information
I also found out that setting the timer to "0" will skip the grub menu and boot into the default OS.
That is correct, yes.
True, you may save a few seconds by doing that, but you may regret it if you need grub menu to access boot options. As I said before in post #6:
