After installing zorinOS 16 on the same sda disk (sda3) as another Linux distribution already installed on another partition (sda4), the hoped-for grub menu at boot time is not displayed.
Please let me know what Terminal commands to enter to restore it.
Thanks.
Does the other Linux Distro use SystemD boot?
If not; Can you please check your grub timeout:
sudo nano /etc/default/grub
Ensure it is set to 10
Test that you can pull up the Grub Menu at boot by tapping the esc
or tab
key (EFI Boot) or the Left Shift key (MBR Legacy - you can just hold this key down instead of stabbing at it) from the motherboard splash screen.
If that is working, then we likely do not have to repair grub.
Great, thanks for reply, yes grub timeout is set to 10 but it boots with the other menu grub I installed first, However, I would like to boot the PC to the GRUB menu of zorinOS.. All installed on UEFI Boot not legacy one.
What about
GRUB_TIMEOUT_STYLE=menu
instead of GRUB_TIMEOUT_STYLE=hidden
Hidden, Sir
Try setting that to menu.
Once done, tap ctrl+x
, then the y
key, then enter
Now, run
sudo update-grub
Reboot and test.
here is the menu grub...
If you change this file, run grub-mkconfig -o /boot/grub/grub.cfg
afterwards to update /boot/grub/grub.cfg.
GRUB_DEFAULT=0
#GRUB_HIDDEN_TIMEOUT=0
GRUB_HIDDEN_TIMEOUT_QUIET=false
GRUB_TIMEOUT=10
GRUB_DISTRIBUTOR="Kali $(cat "/etc/Kali-version"|cut -d" " -f2)"
GRUB_CMDLINE_LINUX_DEFAULT=""
GRUB_CMDLINE_LINUX=""
Uncomment to disable graphical terminal (grub-pc only)
#GRUB_TERMINAL=console
The resolution used on graphical terminal
note that you can use only modes which your graphic card supports via VBE
you can see them in real GRUB with the command `vbeinfo'
#GRUB_GFXMODE=640x480
#GRUB_GFXMODE=1024x768x32
Font used on the graphical terminal:
GRUB_FONT=/usr/share/grub/dejavusansmono.pf2
Uncomment if you don't want GRUB to pass "root=UUID=xxx" parameter to Linux
#GRUB_DISABLE_LINUX_UUID=true
Uncomment to disable generation of recovery mode menu entries
#GRUB_DISABLE_RECOVERY="true"
Enable os-prober to find other distros
GRUB_DISABLE_OS_PROBER="false"
Theme & Background
GRUB_THEME=/boot/grub/themes/Kali/theme.txt
I tried that before, but menu grub still boot from other distro, not zorinOS.
You can add the line if it is not present.
I see your other distro is Kali (Great OS). I do not think that should interfere with an Ubuntu based distro, but I am not certain on that.
You might try
sudo grub-install /dev/sda3
Then boot into Kali and run
sudo grub-install /dev/sda4
Reboot and see if you have access to the menu. Ensure that your Grub Files include
and if you add that line, to run
sudo update-grub
after.
That really Should Work... The usual other cause of osprober failing to recognize a distro is if one is installed MBR and the other EFI.
Typing sudo update-grub shows kali found on dev/sda1, "the zorin distro is on sda4" but not shown after update done...
Ah ok, the OP said sda4. Please adjust the commands as needed.
thanks
receive my dearest greetings
