Why don’t you add a GUI color panel similar to this, that can be used to change intensity of red, green, blue (for all brightness, contrast and gamma), besides hue and saturation? It even allows you to create multiple color profiles:
Hi and welcome to the forum.
Is your post intended to be Feedback to devs, or are you seeking an app solution that matches your "Color Settings" example?
If a solution doesn't exist, i will suggest that to devs. Is that possible here in this forum?
As there are no replies pointing to a solution, I will move this to the "Feedback" section. The devs may be more likely to view suggestions there.
