error, cd-rom doesnt have a release file
As this is a Zorin OS Pro Issue, perhaps you may be better served by using the contact form provided in your purchase of Pro to contact the ZorinGroup directly for assistance.
i have uninstalled nvidia driver but still mouse keyboard not working. work another account.
Try:
mv ~/.config ~/.config-bk
log out and in, test.
not working
You also may consider reinstalling Zorin OS...
Thanks alot, i need recover, should i use "sudo apt install -y gnome gnome-shell zorin-os-desktop-premium" ?
Currently, you have said that is not working.
how to full backup and restore?
This depends on what your goal is.
In your case, due to this transpiring due to a change in Python; I recommend replacing all of Root.
So, your general Home Folder items that you wish to keep:
Documents
Pictures
Music...
You may have items in home you also wish to keep.
Tap the keyboard shortcut ctrl+h
to reveal the "hidden" files.
You should see .config, .local and so on.
You can save your .profile
and if you use conky, .conky
. If you have installed custom fonts, then save .fonts
You will know looking at what needs to be saved.
The way I do this is I simply Compress The Directory that contains what I want to keep and then move that compressed file to a backup storage. USB or External Drive...
Others use the Back-Ups
app in the App menu.
thanks man for your help, i am reinstalling ...
