Happy migration to Zorin Pro 18
So, I have two Ryzen workstations at home.
Due to Windows 10 support ending and Windows 11 being absolutely not what I want, had these computers on Zorin for quite some time now. As soon as I found out about upgrade beta test, I just had to try it.
It was as smooth as it can be - 30 minutes of installation and new version was there.
Have my copy of Pro, not because i consider it better, but just as a token of a tiny support to developers that have done massive work.
So far, the only little glitch is with my Latvia (apostrophe) keyboard, that changes next 2 letters instead of one, but hopefully I'll find a solution.
Major update is done on sound subsystem - I have 2 sound cards and now they work 100% perfect.
Performance is superb.
Thank you guys!
I wish you great success in 2026 with Zorin user numbers multiplying daily and same for supporters with Pro edition!
Keep up the good work and don't become proud when you become famous!
Good to hear that it runs smoothly for You. Because of:
You could open a Help Request Thread and describe it a bit more. Then we could try to solve this.
You could try this solution:
Awesome!
Thank you!
Now everything is 100% perfect!
Glad to hear!
