Hardware Acceleration for GTX 980 TI
Hi all!
I'm quite new to the wonderful world of Linux and have settled on Zorin OS for now. The only real complaint I gave is that whenever I start a Zoom Call, Discord Video or even Youtube my processor usage goes through the roof and usually hovers around 40 %.
From what I understand that points to a problem that the hardware acceleration isn't really working. On windows my gpu hovers around 15 % usage and the processor barely registers. I've attached my setup and I'm running the proprietary nvidia driver 580 and am on Wayland for Zorin OS.
System Details Report
Report details
  • Date generated: 2026-11-11 16:35:55
Hardware Information:
  • Hardware Model: Gigabyte Technology Co., Ltd. Z170X-Gaming 3
  • Memory: 32,0 GiB
  • Processor: Intel® Core™ i7-6700K × 8
  • Graphics: NVIDIA GeForce GTX 980 Ti
  • Disk Capacity: 2,5 TB
Software Information:
  • Firmware Version: F5e
  • OS Name: Zorin OS 18.1 Core
  • OS Build: (null)
  • OS Type: 64-bit
  • Windowing System: Wayland
  • Kernel Version: Linux 7.0.0-42-generic
Have you tryed logging out the click the password area look to bottom right and choose zorin desktop on xorg Nvidia dont like wayland on some gpus from nvidia
I'll give that a try real quick. So something really weird happens when I switch to zorin desktop. The GPU usage hovers around 10 % but the CPU usage remains in the high 30 %.
How do You connect to Zoom and Discord? Via Browser or with dedicated Client? Are all of them install as Flatpak, Snap or APT/.deb Package? What Nvidia Driver do You use?
The nvidia driver is 580 (proprietary). For Dicord I used both the flatpack as well as the apt/den Package. I now use Vestop. For Youtube I just use the default browser which is Brave. Zoom is Flatpak.
You did download the .deb File from Discord directly?
Did You tried it with Firefox?
Maybe try the official .deb Package.
RE: Discord: yes directly from them
RE: Youtube: I did and to the same result
RE: Zoom: I'll give this a try.
From what I understand that all points to a more global problem with my gpu, doesn't it?
Could be but don't have to. When You installed Zorin, did You nstalled it with Nvidia Drivers or without?
Also: Did You tried it with switching to Xorg to see if it behaves there the same?
Since you have an Nvidia GPU, I would also recommend running on X11 as well. Wayland support is still not very stellar for Nvidia GPU's. I looked up your Nvidia GPU, to find out the latest driver that supports it on Linux, is most indeed the 580.105.08, which is the latest legacy driver for it.
Additionally, based on the info you have provided, your system has not updated to use the latest 7.0.0-43 kernel yet. Considering that your GPU is many generations old, I wouldn't expect a newer kernel to necessarily fix the problem, unless there was a later performance fix recently applied. But, just thought you should be aware either way.
We also always recommend, Secure Boot & Fast Boot to be disabled in the computer's BIOS. Which that alone, can fix a whole host of issues. :+1:
Thanks for the tipps! I'll try the x11 again, that's just called zorin desktop right?
I'll check the driver but I'm reasonably sure that that one is installed. I'll also update the kernel to be sure, although I share your doubt that this will actually make a difference.
Fast Boot is disabled and I'm pretty sure I disabled secure boot as well.
What are the normal usage percentages for just watching youtube, a zoom or discord call?
Right. :wink:
Its going to depend on the age of the hardware, the older it is, the greater the number. Using P-Sensor, my Nvidia 5080 is barely pushing 0-1% on graphics, and 28% on memory, while watching YouTube video. My CPU is an AMD 9900X, and is only being pushed 1%.
If I were watching YouTube on a 14 year old computer, it would not be uncommon, to see CPU & GPU usage around 50% minimum.
That depends a bit if You have installed Zotin with Nvidia Drivers or not. When You have it installed with Nvidia Drivers:
  • Zorin Desktop (that is the X11 Option)
  • Zorin Desktop on Wayland
When You have installed Zorin without Nvidia Drivers:
  • Zorin Desktop
  • Zorin Desktop on Xorg (that is the X11 Option)
Is P-Sensor an build in programm? I used ressources to monitor the usage as the default zorin os one didn't have a gpu monitor.
I have attached my system information in the original post. On windows it's around 10 % cpu and 10 % gpu, on cachyos it's around 15 % cpu and 4 % gpu. I'm just trying to understand what would be normal on zorin and not a sign that something is wrong
Hey @Tahnir,
To answer your first question: Psensor isn't built-in, you can grab it right from the Software Store or via terminal (sudo apt install psensor), though the Resources app you're using works great too!
As for your usage numbers: seeing 10%–15% CPU on Windows or CachyOS with your i7-6700K is completely normal, while 35%–40% on Zorin does mean your GPU isn't helping out with the browser rendering or video scaling right now.
There are two main things going on with your setup:
1. The GTX 980 Ti Hardware Limit (Codecs)
Your 980 Ti is a great card, but because it's from the Maxwell generation, its built-in hardware video decoder only supports H.264 and HEVC. YouTube defaults to VP9 and AV1 codecs for almost everything nowadays. Because the 980 Ti can't decode VP9/AV1 in hardware, your i7-6700K has to do the heavy lifting in software—which is why even on Windows/CachyOS you still see ~10–15% CPU usage.
2. Why Zorin is higher (and how to fix it)
On Ubuntu-based distros like Zorin, Brave (and other Chromium browsers) often block GPU acceleration by default on older Nvidia drivers, forcing your CPU to render the entire browser window on top of decoding the video.
You can drop that 40% usage way down with two quick tweaks:
  • Install the enhanced-h264ify extension in Brave: This forces YouTube to send H.264 video streams instead of VP9/AV1. Since your GTX 980 Ti does have full hardware decoding for H.264, it will immediately take the load off your CPU.
  • Force GPU acceleration in Brave: Type brave://flags into your address bar, search for Override software rendering list (#ignore-gpu-blocklist), set it to Enabled, and relaunch Brave. (Note: Make sure you're logged into the X11 "Zorin Desktop" session when testing this, as Nvidia's 580 driver handles browser acceleration much better on X11 than Wayland).
Note: AI was used to craft parts of this response.
