Hi all
, I have posted here all the necessary information regarding the problem I need a solution for. I have internal HDDs in "Other Locations". When I access any of them, the drive mounts and I can interact with the files, but I can't delete anything or create a new folder, etc. The drives seem to act as if they are in "read only" mode. Also, when I try to add one of those HDD disks to the Steam store manager, I get the error message "New Steam library folder must be on a filesystem mounted with execute permissions".
Although I know some concepts, I am new to Linux and need help to solve this problem without damaging the contents of my HDD disks. I appreciate help on this in advance.
Platform: Desktop
BIOS-Motherboard: ASUS ROG MAXIMUS VIII HERO
Fast Startup: Disabled
Secure Boot: Disabled
CSM: Enabled
TPM 2.0: Enabled
Intel Virtualization: Enabled
Graphics Card: NVIDIA GTX 1070System installed: Zorin OS 16.1 Core
Install media: USB flash drive - 64GB
Installation utility: balenaEtcher v1.7.9
Installation via NVIDIA option: Yes
LVM installation option: Disabled
Software updated after installation: Yes
Internet enabled: YesTarget storage drive: SSD (completely empty - full erase - no dual boot)
Additional hard drives: Basic and Dynamic HDD Disks480 GB Disk (2 partitions):
Volume 1 - Size 480 TB
Partition type - Linux Filesystem
Format - Ext4 (1.0) mounted on [root]
Volume 2 - Size 537 MB
Partition Type - EFI System
Format - FAT (32-bit-version) mounted on [/boot/efi]
6 TB Hard Disk (3 partitions):
Format - NTFS
Volume 1 - Size 6.0 TB
Partition Type - Microsoft LDM data
Volume 2 - Size 16 MB
Partition Type - Microsoft Reserved
Volume 3 - Size 1,0 MB
4TB Hard Disk (3 partitions):
Format - NTFS
Volume 1 - Size 4.0TB
Volume 2 - Size 122 MB
4 TB Hard Disk (3 partitions):
Format - NTFS
2 TB Hard Disk (3 partitions):
Format - NTFS
Volume 1 - Size 2.0 TB
Partition Type - NTFS/exFAT/HPFS
Volume 2 - Size 1.1 MB
Unallocated space
