I have and headphone (from logitech) and 2 speakers when I play any audio the headphone and speakers have the same audio from each other Example:I am watching and video the audio is coming out of my headphone and speakers at the same time. when I plug or unplug the headphone from the jack thingy It's create an "headphones 2" or delete it can anyone help me sorry for bad english
What soundcard do you have. Or give details of spec of your machine.
Has this duplicated headphone+speakers output always happened, or since a software update?
You could try Pulse Audio Volume Control. You can install it with sudo apt install pavucontrol
When installed, go to the Output Tab. there You have the Output Sources. On the far right side of Each is a little Marker Icon. Click on it to choose the Default.
When Your Headphones are unplugged, choose Your Speakers. Then plug in the Headphones and check if it automatically switches to them. If not, click on the Marker of the Headphones. Try it then with unplugging the Headphones and check if the Speakers are automatically run and then plug in the Headphones again.
