mhupp
October 19, 2020, 3:50pm
1
I have checked alsamixer and PulseAudio settings, but still cannot get any sound out of headphone jack…when I look at PulseAudio setting, is see sound volume theoretically going to headphones, but hear nothing.
Any works of advice here…I picked HDA Intel PCH card in the AlsaMixer…my chipset is Cirrus Logic CS4206.
Thanks,
Mark
You may try some force:
sudo alsa force-reload
If this does not resolve, you could reinstall alsa and pulseaudio:
sudo apt-get remove --purge alsa-base
sudo apt-get remove --purge pulseaudio
sudo apt-get install alsa-base
sudo apt-get install pulseaudio
Then
Hi, see if these articles help:
After setting up a new computer with Ubuntu 18.04, I noticed there's no sound coming out (from speakers, headphones or HDMI). Looking in the Sound settings (from Gnome Settings), I noticed there's only a Dummy Output as a sound output device.
And I don't know if blacklisting the HDA intel would help at all which is what I had to do to get my SoundBlaster card working:
How to blacklist a sound card in Linux
Sometimes it may happen that you have a sound device that you do not use or then you are one of those people who dislike Pulseaudio and use Alsa instead. Especially with Alsa it gets very useful if you have only the sound device enabled which you actually use. Here are some notes about using Alsa instead of Pulseaudio in Linux.
Start with the minimal installation. When you start with the bare minimum installation (installing only the basic system compo…
