HELP! After booting BIOS a console appears, and I can't use my computer normaly
HELP! After booting BIOS a console appears, and I can't use my computer normaly.
This problem started after uninstalling pipewire, and some files related to pipewire.
Before this problem started some gnome errors started appearing aswell (after removing pipewire)
The files I removed are the following:
pipewire
pipewire-audio-client-libraries
libspa-0.2-bluetooth
I also downloaded the zorin os .iso file to my desktop, but didn't execute it.
Hi, and welcome!
The problem is that you've uninstalled a bunch of dependencies that Zorin OS relies on. In that terminal window you can start by re-installing the desktop and see if there's some progress:
sudo apt install zorin-os-desktop
And reboot:
sudo reboot
Thank you very much! Everything is back to normal now.
