hello,
i would like to change the icon for desktop directory to match others(earlier it was similar to others and i have no idea what changed it)
I am using zorin core 16.2
hello,
What icon theme are you using?
zorin os dark purple
well i should have looked carefully before posting.
Turns out there is option to do that in file itself
rightclick-->preferences-->click on the icon-->select new icon(it comes with a handy search)
