error for any equation
with this line highlighted
what i tried
reinstalling writer
reinstalling the extension
using an older version of the extension
realize this is more of a librewriter problem than Zorin OS so if this topic is out of scope of this forum I'll delete it
none, I am using texmath to insert latex equations.
In case you are unfamiliar latex is a text editing language (like markdown) to insert math equations it doesn't do any calculations.
As for
All inputs even normal letters like just "x" will give an error
Yes, I have been using Latex for years. I have never used TexMaths in Libreoffice, though. I was under the impression it can be used with LibreCalc... I think I must be wrong on that.
I see. That definitely sounds broken.
Have you tried
mv ~/.config ~/config-bk
Then completely removing and reinstalling the Libreoffice extension?
Or the extension and Libreoffice...
After reinstalling - log out and in and then test the new install of it.
Unfortunately that didn't work, and as i have to use writer urgently ,i couldn't afford to troubleshoot it any further so i used a time shift backup ,and now things seem to be working
