hello,
i would like to disable magic lamp gnome tweak. currently when i disable it from the application apps it re-enables after restarting the pc
Thanks.
Are there any entries for Magic Lamp Extension in your ~/.config directory?
there is a folder with that name in usr/share/doc which contains changelog.gz
should i delete that?
No, files in Root should be left alone.
Your Home (~)/.config directory is a Personalization Directory - it is where your preferred individual settings are kept.
Whereas other locations may contain a System File for that application; which is what makes it run and function.
You do raise a point: Uninstalling Magic Lamp would be one way of disabling it...
It would be gone unless you reinstall it.
sudo apt remove gnome-shell-extension-zorin-magic-lamp-effect
Are you sure that this lamp effect that you say aren't the Interface options on Zorin Appearance? Because after disabling them I saw a different look on restoring and minimizing windows, the jelly option gives an animation like a lamp effect but I may be wrong, I just searched this effect on Google and saw some similarities ![]()
