Hi, I’m currently having a glitch on my computer. (I’m french so my english is not always perfect)
This is the glitch.
It happens very randomly, once or twice every minutes, and last from 5 to 20 seconds every time. Sometimes it continues with some softwares opened (like the terminal) and sometimes it completly stops with others like Pycharm.
I already had this problem before and I reinstalled Zorin on my PC but the problem still remains.
My PC is a GPD MicroPC
These are the lshw outputs :
PC-micropc
description: Ordinateur Bloc-notes
produit: MicroPC (Default string)
fabricant: GPD
version: Default string
numéro de série: Default string
bits: 64 bits
fonctionnalités: smbios-3.2.0 dmi-3.2.0 smp vsyscall32
configuration : boot=normal chassis=notebook family=Default string
sku=Default string uuid=00020003-0004-0005-0006-000700080009
*-core
description: Carte mère
produit: MicroPC
fabricant: GPD
identifiant matériel: 0
emplacement: Default string
*-firmware
description: BIOS
fabricant: American Megatrends Inc.
version: 4.18
date: 06/01/2020
taille: 64KiB
capacité: 4928KiB
fonctionnalités: pci upgrade shadowing cdboot bootselect
socketedrom edd int13floppy1200 int13floppy720 int13floppy2880
int5printscreen int14serial int17printer acpi usb biosbootspecification
uefi
*-memory
description: Mémoire Système
identifiant matériel: 23
emplacement: Carte mère
taille: 8GiB
*-bank:0
description: DIMM LPDDR4 Synchrone 2133 MHz (0,5 ns)
produit: 123456789012345678
fabricant: ABCD
numéro de série: 1234
emplacement: A1_DIMM0
taille: 4GiB
bits: 16 bits
horloge: 2133MHz (0.5ns)
*-bank:1
fabricant: ABCD
identifiant matériel: 1
emplacement: A1_DIMM1
taille: 4GiB
bits: 16 bits
*-cache:0
description: L1 cache
identifiant matériel: 2f
emplacement: CPU Internal L1
taille: 224KiB
capacité: 224KiB
fonctionnalités: synchronous internal write-back
configuration : level=1
*-cache:1
description: L2 cache
identifiant matériel: 30
emplacement: CPU Internal L2
taille: 4MiB
capacité: 4MiB
fonctionnalités: synchronous internal write-back unified
configuration : level=2
*-cpu
description: CPU
produit: Intel(R) Celeron(R) N4100 CPU @ 1.10GHz
fabricant: Intel Corp.
identifiant matériel: 31
information bus: cpu@0
version: Intel(R) Celeron(R) N4100 CPU @ 1.10GHz
emplacement: SOCKET 0
taille: 1650MHz
capacité: 2700MHz
bits: 64 bits
horloge: 100MHz
fonctionnalités: lm fpu fpu_exception wp vme de pse tsc msr
pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx
fxsr sse sse2 ss ht tm pbe syscall nx pdpe1gb rdtscp x86-64
constant_tsc art arch_perfmon pebs bts rep_good nopl xtopology
nonstop_tsc cpuid aperfmperf tsc_known_freq pni pclmulqdq dtes64
monitor ds_cpl vmx est tm2 ssse3 sdbg cx16 xtpr pdcm sse4_1 sse4_2
x2apic movbe popcnt tsc_deadline_timer aes xsave rdrand lahf_lm
3dnowprefetch cpuid_fault cat_l2 pti cdp_l2 ssbd ibrs ibpb stibp
ibrs_enhanced tpr_shadow vnmi flexpriority ept vpid ept_ad fsgsbase
tsc_adjust smep erms mpx rdt_a rdseed smap clflushopt intel_pt sha_ni
xsaveopt xsavec xgetbv1 xsaves dtherm ida arat pln pts umip rdpid
md_clear arch_capabilities cpufreq
configuration : cores=4 enabledcores=4 threads=4
*-pci
description: Host bridge
produit: Gemini Lake Host Bridge
fabricant: Intel Corporation
identifiant matériel: 100
information bus: pci@0000:00:00.0
version: 03
bits: 32 bits
horloge: 33MHz
*-generic:0
description: Signal processing controller
produit: Celeron/Pentium Silver Processor Dynamic Platform
and Thermal Framework Processor Participant
identifiant matériel: 0.1
information bus: pci@0000:00:00.1
version: 03
bits: 64 bits
horloge: 33MHz
fonctionnalités: pm bus_master cap_list
configuration : driver=proc_thermal latency=0
ressources : irq:24 mémoire:80000000-80007fff
*-display
produit: UHD Graphics 605
information bus: pci@0000:00:02.0
version: 03
bits: 64 bits
horloge: 33MHz
fonctionnalités: pciexpress msi pm vga_controller
bus_master cap_list rom
configuration : driver=i915 latency=0
ressources : irq:127 mémoire:a0000000-a0ffffff
mémoire:90000000-9fffffff portE/S:f000(taille=64) mémoire:c0000-dffff
*-multimedia
description: Audio device
produit: Intel Corporation
identifiant matériel: e
information bus: pci@0000:00:0e.0
version: 03
bits: 64 bits
horloge: 33MHz
fonctionnalités: pm msi pciexpress bus_master cap_list
configuration : driver=snd_hda_intel latency=0
ressources : irq:129 mémoire:a1310000-a1313fff
mémoire:a1000000-a10fffff
*-communication
description: Communication controller
produit: Celeron/Pentium Silver Processor Trusted
Execution Engine Interface
identifiant matériel: f
information bus: pci@0000:00:0f.0
version: 03
bits: 64 bits
horloge: 33MHz
fonctionnalités: pm msi bus_master cap_list
configuration : driver=mei_me latency=0
ressources : irq:128 mémoire:a1337000-a1337fff
*-sata
description: SATA controller
identifiant matériel: 12
information bus: pci@0000:00:12.0
version: 03
bits: 32 bits
horloge: 66MHz
fonctionnalités: sata msi pm ahci_1.0 bus_master cap_list
configuration : driver=ahci latency=0
ressources : irq:124 mémoire:a1314000-a1315fff
mémoire:a1336000-a13360ff portE/S:f090(taille=8) portE/S:f080(taille=4)
portE/S:f060(taille=32) mémoire:a1335000-a13357ff
*-pci:0
description: PCI bridge
produit: Gemini Lake PCI Express Root Port
identifiant matériel: 13
information bus: pci@0000:00:13.0
version: f3
bits: 32 bits
horloge: 33MHz
fonctionnalités: pci pciexpress msi pm normal_decode
bus_master cap_list
configuration : driver=pcieport
ressources : irq:122 mémoire:a1200000-a12fffff
*-network
description: Interface réseau sans fil
produit: Wireless 7265
information bus: pci@0000:01:00.0
nom logique: wlp1s0
version: 59
numéro de série: b8:9a:2a:43:38:52
bits: 64 bits
horloge: 33MHz
ethernet physical wireless
configuration : broadcast=yes driver=iwlwifi
driverversion=5.15.0-89-generic firmware=29.1654887522.0 7265D-29.ucode
ip=192.168.16.111 latency=0 link=yes multicast=yes wireless=IEEE 802.11
ressources : irq:130 mémoire:a1200000-a1201fff
*-pci:1
identifiant matériel: 13.2
information bus: pci@0000:00:13.2
version: f3
bits: 32 bits
horloge: 33MHz
bus_master cap_list
ressources : irq:123 portE/S:e000(taille=4096)
mémoire:a1100000-a11fffff
*-network
produit: RTL8111/8168/8411 PCI Express Gigabit Ethernet
Controller
fabricant: Realtek Semiconductor Co., Ltd.
information bus: pci@0000:02:00.0
nom logique: eno1
version: 15
numéro de série: 00:9e:9f:03:02:57
capacité: 1Gbit/s
bits: 64 bits
horloge: 33MHz
fonctionnalités: pm msi pciexpress msix bus_master
cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt-fd
autonegotiation
configuration : autonegotiation=on broadcast=yes
driver=r8169 driverversion=5.15.0-89-generic firmware=rtl8168h-2_0.0.2
02/26/15 latency=0 link=no multicast=yes port=twisted pair
ressources : irq:20 portE/S:e000(taille=256)
mémoire:a1104000-a1104fff mémoire:a1100000-a1103fff
*-usb
description: USB controller
identifiant matériel: 15
information bus: pci@0000:00:15.0
version: 03
bits: 64 bits
horloge: 33MHz
fonctionnalités: pm msi xhci bus_master cap_list
configuration : driver=xhci_hcd latency=0
ressources : irq:125 mémoire:a1300000-a130ffff
*-usbhost:0
produit: xHCI Host Controller
fabricant: Linux 5.15.0-89-generic xhci-hcd
information bus: usb@1
nom logique: usb1
version: 5.15
fonctionnalités: usb-2.00
configuration : driver=hub slots=9 speed=480Mbit/s
*-usb:0
description: Clavier
produit: USB KEYBOARD
fabricant: AMR-4630-XXX-0- 0-1023
information bus: usb@1:3
version: 2.00
fonctionnalités: usb-1.10
configuration : driver=usbhid maxpower=100mA
speed=1Mbit/s
*-usb:1
description: Interface sans fil Bluetooth
identifiant matériel: 4
information bus: usb@1:4
version: 0.03
fonctionnalités: bluetooth usb-2.00
configuration : driver=btusb maxpower=100mA
speed=12Mbit/s
*-usbhost:1
information bus: usb@2
nom logique: usb2
version: 5.15
fonctionnalités: usb-3.00
configuration : driver=hub slots=7 speed=5000Mbit/s
*-usb
description: Périphérique de stockage de masse
produit: USB3.0-CRW
fabricant: Generic
information bus: usb@2:1
version: 2.04
numéro de série: 20120501030900000
fonctionnalités: usb-3.00 scsi
configuration : driver=usb-storage maxpower=800mA
speed=5000Mbit/s
*-generic:1
produit: Celeron/Pentium Silver Processor Serial IO I2C
Host Controller
identifiant matériel: 16
information bus: pci@0000:00:16.0
version: 03
bits: 64 bits
horloge: 33MHz
configuration : driver=intel-lpss latency=0
ressources : irq:27 mémoire:a1334000-a1334fff
mémoire:a1333000-a1333fff
*-generic:2
Host Controller
identifiant matériel: 16.1
information bus: pci@0000:00:16.1
version: 03
bits: 64 bits
horloge: 33MHz
ressources : irq:28 mémoire:a1332000-a1332fff
mémoire:a1331000-a1331fff
*-generic:3
identifiant matériel: 16.2
information bus: pci@0000:00:16.2
version: 03
bits: 64 bits
horloge: 33MHz
ressources : irq:29 mémoire:a1330000-a1330fff
mémoire:a132f000-a132ffff
*-generic:4
identifiant matériel: 16.3
information bus: pci@0000:00:16.3
version: 03
bits: 64 bits
horloge: 33MHz
ressources : irq:30 mémoire:a132e000-a132efff
mémoire:a132d000-a132dfff
*-generic:5
identifiant matériel: 17
information bus: pci@0000:00:17.0
version: 03
bits: 64 bits
horloge: 33MHz
ressources : irq:31 mémoire:a132c000-a132cfff
mémoire:a132b000-a132bfff
*-generic:6
identifiant matériel: 17.1
information bus: pci@0000:00:17.1
version: 03
bits: 64 bits
horloge: 33MHz
ressources : irq:32 mémoire:a132a000-a132afff
mémoire:a1329000-a1329fff
*-generic:7
identifiant matériel: 17.2
information bus: pci@0000:00:17.2
version: 03
bits: 64 bits
horloge: 33MHz
ressources : irq:33 mémoire:a1328000-a1328fff
mémoire:a1327000-a1327fff
*-generic:8
identifiant matériel: 17.3
information bus: pci@0000:00:17.3
version: 03
bits: 64 bits
horloge: 33MHz
ressources : irq:34 mémoire:a1326000-a1326fff
mémoire:a1325000-a1325fff
*-generic:9
produit: Celeron/Pentium Silver Processor Serial IO UART
Host Controller
identifiant matériel: 18
information bus: pci@0000:00:18.0
version: 03
bits: 64 bits
horloge: 33MHz
ressources : irq:4 mémoire:a1324000-a1324fff
mémoire:a1323000-a1323fff
*-generic:10
Host Controller
identifiant matériel: 18.1
information bus: pci@0000:00:18.1
version: 03
bits: 64 bits
horloge: 33MHz
ressources : irq:5 mémoire:a1322000-a1322fff
mémoire:a1321000-a1321fff
*-generic:11
Host Controller
identifiant matériel: 18.2
information bus: pci@0000:00:18.2
version: 03
bits: 64 bits
horloge: 33MHz
ressources : irq:6 mémoire:fea10000-fea10fff
mémoire:fee01000-fee01fff
*-generic:12
Host Controller
identifiant matériel: 18.3
information bus: pci@0000:00:18.3
version: 03
bits: 64 bits
horloge: 33MHz
ressources : irq:7 mémoire:a1320000-a1320fff
mémoire:a131f000-a131ffff
*-generic:13
produit: Celeron/Pentium Silver Processor Serial IO SPI
Host Controller
identifiant matériel: 19
information bus: pci@0000:00:19.0
version: 03
bits: 64 bits
horloge: 33MHz
ressources : irq:35 mémoire:a131e000-a131efff
mémoire:a131d000-a131dfff
*-generic:14
Host Controller
identifiant matériel: 19.1
information bus: pci@0000:00:19.1
version: 03
bits: 64 bits
horloge: 33MHz
ressources : irq:36 mémoire:a131c000-a131cfff
mémoire:a131b000-a131bfff
*-generic:15
Host Controller
identifiant matériel: 19.2
information bus: pci@0000:00:19.2
version: 03
bits: 64 bits
horloge: 33MHz
ressources : irq:37 mémoire:a131a000-a131afff
mémoire:a1319000-a1319fff
*-generic:16
description: SD Host controller
produit: Celeron/Pentium Silver Processor SDA Standard
Compliant SD Host Controller
identifiant matériel: 1c
information bus: pci@0000:00:1c.0
version: 03
bits: 64 bits
horloge: 33MHz
configuration : driver=sdhci-pci latency=0
ressources : irq:39 mémoire:a1318000-a1318fff
mémoire:a1317000-a1317fff
*-isa
description: ISA bridge
identifiant matériel: 1f
information bus: pci@0000:00:1f.0
version: 03
bits: 32 bits
horloge: 33MHz
fonctionnalités: isa bus_master
configuration : latency=0
*-serial
description: SMBus
produit: Celeron/Pentium Silver Processor Gaussian Mixture
Model
identifiant matériel: 1f.1
information bus: pci@0000:00:1f.1
version: 03
bits: 64 bits
horloge: 33MHz
configuration : driver=i801_smbus latency=0
ressources : irq:20 mémoire:a1316000-a13160ff
portE/S:f040(taille=32)
*-pnp00:00
produit: PnP device PNP0c02
fonctionnalités: pnp
configuration : driver=system
*-pnp00:01
produit: PnP device PNP0303
configuration : driver=i8042 kbd
*-pnp00:02
produit: PnP device PNP0501
configuration : driver=serial
*-pnp00:03
*-pnp00:04
identifiant matériel: 5
*-pnp00:05
produit: PnP device PNP0b00
identifiant matériel: 6
configuration : driver=rtc_cmos
*-scsi:0
identifiant matériel: 7
nom logique: scsi0
fonctionnalités: emulated
*-disk
description: ATA Disk
produit: BIWIN SSD
identifiant matériel: 0.0.0
information bus: scsi@0:0.0.0
nom logique: /dev/sda
version: 4A0
numéro de série: 1949028301044
taille: 119GiB (128GB)
fonctionnalités: gpt-1.00 partitioned partitioned:gpt
configuration : ansiversion=5 guid=a27983e3-0e98-4b87-
a147-63e714f076c9 logicalsectorsize=512 sectorsize=512
*-volume:0 NON-RÉCLAMÉ
description: Windows FAT volume
fabricant: MSWIN4.1
information bus: scsi@0:0.0.0,1
version: FAT32
numéro de série: cb04-77e2
taille: 482MiB
capacité: 511MiB
fonctionnalités: boot fat initialized
configuration : FATs=2 filesystem=fat name=EFI System
Partition
*-volume:1
description: Volume EXT4
fabricant: Linux
information bus: scsi@0:0.0.0,2
nom logique: /dev/sda2
nom logique: /
version: 1.0
numéro de série: 63d6d510-f732-493f-a05b-d9502711ca9a
taille: 118GiB
fonctionnalités: journaled extended_attributes
large_files huge_files dir_nlink recover 64bit extents ext4 ext2
initialized
configuration : created=2023-11-22 10:55:05
filesystem=ext4 lastmountpoint=/ modified=2023-11-23 13:59:21
mount.fstype=ext4 mount.options=rw,relatime,errors=remount-ro
mounted=2023-11-23 13:59:22 state=mounted
*-scsi:1
identifiant matériel: 8
nom logique: scsi2
fonctionnalités: emulated scsi-host
*-disk
description: SCSI Disk
produit: SD/MMC
fabricant: Generic-
information bus: scsi@2:0.0.0
nom logique: /dev/sdb
version: 1.00
numéro de série: 2012090114345300
fonctionnalités: removable
configuration : ansiversion=6 logicalsectorsize=512
sectorsize=512
*-medium
