I recently installed Zorin OS Lite and I was exploring its options and I installed BleachBit to free up space but I fill up my hard drive and when I turn on my laptop I get the login tab but when I put my password the screen goes black and it comes back to the login part.
"I use the translator"
Can you run this in terminal
df -h
and post the output here?
I think @tomlite is saying that the login greeter is not accepting the password so it’s not possible to get to the desktop. To run the command, one would need to access one of the other virtual sessions via Ctrl+Alt+F2 or F3 first. Log in there and then run the command.
