But in the desription of VLC Media Player in the Software Manager it is written that is never updated i.e., of oldest version..
If you choose Flathub (upper right corner of Software Manager), it will get updated continuously.
I don't know if there's a PPA for vlc ifyou want to avoid flat/snap
Most of the Linux apps are installed "within" the OS.
It is a big difference from Windows where downloading installers are required (except for Windows Store apps).
To install VLC,
- Open the Terminal (ctrl+alt+T)
- Issue the following commands (one line at a time)
sudo apt update
sudo apt install vlc
Type the password when prompt asks for it (you will not see what you are typing for security reason)
To install the latest VLC, please follow the instruction at the bottom of this page by adding PPA.
