I have basically messed up bigtime, and I don't know what went wrong.
I wanted to change my driver's from the open source xorg ones to the latest drivers for my gpu: nvidia GeForce 610m.
I looked up on the web to see what version of what drivers I need to install for my gpu and I found it out.
I went to additional drivers application and saw that the driver version for my gpu was already an option for me to switch to and I didn't need to download it seperately from the internet.
I switched to those nvidia drivers and applied the changes.
I then restarted my laptop and was welcomed by a screen displaying the message:
"A problem has occured and the system can't recover. Please contact a system administrator"
Here's an image:
I'd really appreciate any help!
hoping to recover my data and system in one piece...
(p.s I'm extremely new to Linux)
(edit: I think the problem will be solved if I switch to the previous xorg drivers, but I can't boot up the system to apply those changes anymore so I'm stuck.)
Don't panic. There is a Good Chance that re-installing Zorin OS is not in your future just yet.
Can you hold or tap the left shift key at boot to access teh Recovery Menu? This menu will have Advanced Options for Zorin.
Open that, then arrow key down to enable networking
Back up to the Recovery Menu...
Then arrow key down to Drop to Prompt
hit enter...
Then type in (Make sure no typoes):
An earlier thread where I was trying so hard to solve a problem, I never stopped to consider whether it even was a problem (It wasn't) and I was barking up the wrong tree.
Great for popcorn.
