Hello, i;'m using dell latitiude 7390 user. and dualbooted the zorin os with windows and i have a problem. Sometimes it just restarts and i have to log in again and lose eveything i opened up. or sometimes the pc is very slow and then it restarts by it self. so can any one suggest me a way or command to find this out? thanks for the advice.
In most cases, these sudden restarts are linked to one of three common issues: GPU driver instability, faulty RAM, or thermal throttling/overheating.
- Are Secure Boot and Fast Boot in BIOS disabled?
- Is Fast Start-Up in Windows disabled?
- Does Your BIOS run in UEFI or Legacy Mode?
- What Tool did You use to create the bottable USB Stick with Zorin on it?
- When this happens what Programs Taska have You open?
- Can You post Your Hardware Specs?
